Four Switches with Stack 3750 10/1000 CPU usage 100 % simultaniously
Hi All,
sh processes cpu history, What is the Cause of this problem, becuase of this Network is getting down in entire network,
    6668966666756922212222124422212222222122222222222222122122
    1210938912210656383872837721491432223864124205354827445540
100     *        *
90     *        *
80    *#        *
70    *# **  *  *
60 ****#****** **
50 ****#*********          **
40 ****#*********          **
30 ###########**#**   **   **            *      * * * *  *
20 ##############**#**********************************# *****
10 ##########################################################
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    5343266623434556338343324238354342332343433333233282535256435437334344
    2518730354524518700109392450901216679522763520415847061734059563216436
100
90
80                   *        *                      *
70                *  *        *                      *            *
60      ***     * *  *        *                      *      *  *  *
50 *    ***  *  ***  *        * *          *         * * * **  ** *  *  *
40 **** ***  * ***** * **  * ***** * ** ** ** *    * * *** ********  * **
30 ************************* ******************** ***********************
20 **********************************************************************
10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
5 Replies 5
acampbell
Aman,
There are many items that could cause this issue.
Like spanning tree loops etc
Try
show proc cpu sorted
This should output the league table of what is consuming the CPU,
with the greediest at the top.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Leo Laohoo
Would be nice if you post what IOS you are currently running.
InayathUlla Sharieff
Hi Aman,
In addition please provide us the following outputs:
show version
show proc cpu sorted | ex 0.0
show proc cpu history
show controllers cpu-interfac
show platform port-asic stats drop
Inayath
here is the out put of
show version
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 23-Jul-12 13:22 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
RDCCI37F0 uptime is 18 weeks, 3 days, 11 hours, 27 minutes
System restarted at 21:27:44 MSK Fri Sep 28 2012
System image file is "flash:c3750-ipservicesk9-mz.122-55.SE6/c3750-ipservicesk9-mz.122-55.SE6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-48P (PowerPC405) processor (revision J0) with 131072K bytes of memory.
Processor board ID CAT1018R31J
Last reset from power-on
2 Virtual Ethernet interfaces
192 FastEthernet interfaces
16 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:17:E0:67:2F:00
Motherboard assembly number     : 73-9675-11
Power supply part number        : 341-0029-04
Motherboard serial number       : CAT1017086B
Power supply serial number      : LIT1012032Y
Model revision number           : J0
Motherboard revision number     : A0
--More--                           Model number                    : WS-C3750-48PS-S
System serial number            : CAT1018R31J
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT10171KTE
Top Assembly Part Number        : 800-25858-03
Top Assembly Revision Number    : F0
Version ID                      : V05
CLEI Code Number                : COM1W00ARB
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
     1 52    WS-C3750-48P       12.2(55)SE6           C3750-IPSERVICESK9-M
     2 52    WS-C3750-48P       12.2(55)SE6           C3750-IPSERVICESK9-M
*    3 52    WS-C3750-48P       12.2(55)SE6           C3750-IPSERVICESK9-M
     4 52    WS-C3750-48P       12.2(55)SE6           C3750-IPSERVICESK9-M
Switch 01
Switch Uptime                   : 18 weeks, 3 days, 11 hours, 27 minutes
Base ethernet MAC Address       : 00:14:F2:00:FA:00
Motherboard assembly number     : 73-9675-17
Power supply part number        : 341-0029-05
Motherboard serial number       : CAT09260Y05
Power supply serial number      : DTN125140EL
Model revision number           : H0
System serial number            : CAT0926N2S0
SFP Module revision number      : A0
SFP Module serial number        : CAT09241KM8
Top assembly part number        : 800-25858-08
Top assembly revision number    : A0
Version ID                      : V10
CLEI Code Number                : COMAH10BRA
Switch 02
Base ethernet MAC Address       : 00:17:E0:FB:4A:00
--More--                           Motherboard serial number       : CAT1018018H
Power supply serial number      : LIT10120362
System serial number            : CAT1018R2YB
SFP Module serial number        : CAT10171JBM
Top assembly part number        : 800-25858-03
Top assembly revision number    : F0
Version ID                      : V05
Switch 04
Switch Uptime                   : 18 weeks, 3 days, 11 hours, 16 minutes
Base ethernet MAC Address       : 00:1E:49:F8:D3:80
Motherboard serial number       : FDO114507GV
Power supply serial number      : LIT11410GXR
Model revision number           : K0
Motherboard revision number     : B0
System serial number            : FDO1145X2JG
SFP Module serial number        : FDO114503J7
Top assembly revision number    : J0
Version ID                      : V05
Configuration register is 0xF
RDCCI37F0#show proc cpu sorted | ex 0.0
CPU utilization for five seconds: 11%/1%; one minute: 12%; five minutes: 12%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   9   208999294 229139920        912  2.39%  1.72%  1.90%   0 ARP Input
  68    36294624 586768083         61  0.63%  0.35%  0.29%   0 Fifo Error Detec
103    29029344 149237236        194  0.47%  0.23%  0.18%   0 hpm main process
251    73618720  24512848       3003  0.31%  0.63%  0.60%   0 Marvell wk-a Pow
146    64054978 264479575        242  0.31%  0.52%  0.55%   0 Hulc LED Process
231    16197753  17096266        947  0.31%  0.15%  0.14%   0 IPC LC Message H
107    27695859  23198743       1193  0.15%  0.24%  0.27%   0 hpm counter proc
207    25784237  77440696        332  0.15%  0.23%  0.31%   0 IP Input
108    20824663  72331071        287  0.15%  0.20%  0.17%   0 HRPC pm-counters
221    20326958  76187435        266  0.15%  0.15%  0.15%   0 Spanning Tree
156    35462717  17854228       1986  0.15%  0.33%  0.32%   0 HRPC qos request
201    17863448  18592442        960  0.15%  0.15%  0.15%   0 CDP Protocol
RDCCI37F0#show proc cpu history
    1111111111111111111111111111111111112222211111111111111111
    5111111111100000000000000000000000004444433333111110000000
100
90
80
70
60
50
40
30
20 *                                   *****
10 **********************************************************
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    2222211222222222222122221222221212212822222212212221222222
    4042187111333211105451337112259340373021111394690039371631
100
90
80                                      *
70                                      *
60                                      *
50                                      *
40                                      *
30                   * *        *       *        *      * *
20 ******************* ************ ****#********************
             0    5    0    5    0    5    0    5    0    5
    9346443443534333543843433363652237344353995343266623434556338343324238
    2693431017037991798427582019567671827274992518730354524518700109392450
100                                         **
90 *                                       **
80 *                  *                    **                  *        *
70 *                  *        *    *      **               *  *        *
60 *  *            *  *      * **   *    * **     ***     * *  *        *
50 * **      * *   ** *  *   * **   *  * * ***    ***  *  ***  *        *
40 ****** **** *** ********  ****  ***** * ****** ***  * ***** * **  * **
30 ******************************************************************* **
20 ****************************************##****************************
--More--                              0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
RDCCI37F0#show controllers cpu-interfac
ASIC    Rxbiterr   Rxunder    Fwdctfix   Txbuflos   Rxbufloc   Rxbufdrain
ASIC0     0          0          0          0          0          0
ASIC1     0          0          0          0          0          0
HOL Fix Counts
No Fixes:          0 Added:          0 In Use:          0 Both:          0
CPU Heartbeat Statistics
Tx Success Tx Fail    1st Thr    2nd Thr    Unthr      RetryCtMax
222242642          0          0          0          0          1
Rx Delay
         0          1          2          3          4
222242642          0          0          0          0
AddlDelay AdvanceCnt
         0          0
Rx Retries by RetryCount
         0          1          2          3          4          5          6
222242642          0          0          0          0          0          0
         7          8          9
         0          0          0
AddlRetry
cpu-queue-frames  retrieved  dropped    invalid    hol-block  stray
rpc               614263200  0          0          0          0
stp               72674914   0          0          0          0
ipc               99470973   0          0          0          0
routing protocol  289267059  0          0          0          0
L2 protocol       6113187    0          0          0          0
remote console    1340       0          0          0          0
--More--                           sw forwarding     18246      0          0          0          0
host              564528     0          0          0          0
broadcast         345288241  0          0          0          0
cbt-to-spt        0          0          0          0          0
igmp snooping     15822592   0          0          0          0
icmp              0          0          0          0          0
logging           0          0          0          0          0
rpf-fail          0          0          0          0          0
dstats            0          0          0          0          0
cpu heartbeat     222242665  0          0          0          0
cpu-queue         static inuse static added
rpc               0            0
stp               0            0
ipc               0            0
routing protocol  0            0
L2 protocol       0            0
remote console    0            0
sw forwarding     0            0
host              0            0
broadcast         0            0
cbt-to-spt        0            0
igmp snooping     0            0
icmp              0            0
logging           0            0
rpf-fail          0            0
dstats            0            0
cpu heartbeat     0            0
Supervisor ASIC receive-queue parameters
queue 0 maxrecevsize 7E0 pakhead 55C2F9C paktail 47EB6F8
queue 1 maxrecevsize 7E0 pakhead 4899BE0 paktail 489A318
queue 2 maxrecevsize 7E0 pakhead 562DF28 paktail 562DB8C
queue 3 maxrecevsize 7E0 pakhead 5A66FEC paktail 5A6E36C
queue 4 maxrecevsize 7E0 pakhead 48AB568 paktail 575821C
queue 5 maxrecevsize 7E0 pakhead 4AEA7C8 paktail 5A513D4
queue 6 maxrecevsize 7E0 pakhead 4AFBE84 paktail 5A5BF10
queue 7 maxrecevsize 7E0 pakhead 4A8D0E8 paktail 4A981C4
queue 8 maxrecevsize 7E0 pakhead 5A01A94 paktail 4A9A5DC
queue 9 maxrecevsize 7E0 pakhead 5955BB8 paktail 5955BB8
queue A maxrecevsize 7E0 pakhead 4986D60 paktail 594D4F0
queue B maxrecevsize 7E0 pakhead 4B11310 paktail 5A7307C
queue C maxrecevsize 7E0 pakhead 49A4278 paktail 5965D78
queue D maxrecevsize 7E0 pakhead 499BBE0 paktail 595581C
--More--                            queue E maxrecevsize 0 pakhead 0 paktail 0
queue F maxrecevsize 7E0 pakhead 5943388 paktail 497DC18
Supervisor ASIC exception status
Receive overrun    00000000   Transmit overrun 00000000
FrameSignatureErr  00000000   MicInitialize    00000000
BadFrameErr        00000000   LenExceededErr   00000000
BadJumboSegments   00000000
Supervisor ASIC Mic Registers
MicDirectPollInfo             80000200
MicIndicationsReceived        00000000
MicInterruptsReceived        00000000
MicPcsInfo                   0000001F
MicPlbMasterConfiguration    00000000
MicRxFifosAvailable          00000000
MicRxFifosReady              0000BFFF
MicTimeOutPeriod:    FrameTOPeriod: 00000EA6    DirectTOPeriod: 00004000
MicTransmFramesCopied        00000003
MicTxFifosAvailable          00000003
MicConfiguration:    Conf flag: 00000110    Interrupt Flag: 0000000A
MicReceiveFifoAssignmen    Queue 0 - 7: 00000000    Queue 8 - 15:00000000
MicReceiveFramesReady:    FrameAvailable: 00000001    frameAvaiMask: 00000000
MicException:
    Exception_flag    00000000
    Message-1    00000000
    Message-2    00000000
    Message-3    00000000
MicIntRxFifo:
    ReadPtr        00000748    WritePtr    00000748
    WHeadPtr    00000748    TxFifoDepth    C0000800
MicIntTxFifo:
    ReadPtr        000008F0    WritePtr    000008F0
    WHeadPtr    000008F0    TxFifoDepth    C0000800
MicDecodeInfo:
Fifo0:    address:    03FF4000 asic_num:    00000100
Fifo1:    address:    03FF4400 asic_num:    00000101
MicTransmitFifoInfo:
Fifo0:     StartPtrs:    066C9000    ReadPtr:    066C91F8
    WritePtrs:    066C91F8    Fifo_Flag:    8A800800
    Weights:    001E001E
Fifo1:     StartPtrs:    06427400    ReadPtr:    06427590
    WritePtrs:    06427590    Fifo_Flag:    89800400
    Weights:    000A000A
MicReceiveFifoInfo:
--More--                           Fifo0:    StartPtr:    066DD000    ReadPtr:    066DDED0
    WritePtrs:    066DDF30    Fifo_Flag:    8B000FA0
    writeHeaderPtr:    066DDF30
Fifo1:    StartPtr:    069DA800    ReadPtr:    069DAB78
    WritePtrs:    069DAB78    Fifo_Flag:    89800400
    writeHeaderPtr:    069DAB78
Fifo2:    StartPtr:    06993000    ReadPtr:    06993018
    WritePtrs:    06993018    Fifo_Flag:    89800400
    writeHeaderPtr:    06993018
Fifo3:    StartPtr:    06BEF800    ReadPtr:    06BEF980
    WritePtrs:    06BEF980    Fifo_Flag:    89800400
    writeHeaderPtr:    06BEF980
Fifo4:    StartPtr:    06A22000    ReadPtr:    06A22138
    WritePtrs:    06A22138    Fifo_Flag:    89800400
    writeHeaderPtr:    06A22138
Fifo5:    StartPtr:    06B5EE00    ReadPtr:    06B5EFE0
    WritePtrs:    06B5EFE0    Fifo_Flag:    88800200
    writeHeaderPtr:    06B5EFE0
Fifo6:    StartPtr:    06BA5C00    ReadPtr:    06BA5E30
    WritePtrs:    06BA5E30    Fifo_Flag:    89800400
    writeHeaderPtr:    06BA5E30
Fifo7:    StartPtr:    06ACE800    ReadPtr:    06ACE9A0
    WritePtrs:    06ACE9A0    Fifo_Flag:    89800400
    writeHeaderPtr:    06ACE9A0
Fifo8:    StartPtr:    06B38E00    ReadPtr:    06B38E30
    WritePtrs:    06B38E30    Fifo_Flag:    88800200
    writeHeaderPtr:    06B38E30
Fifo9:    StartPtr:    066DB4D8    ReadPtr:    066DB4D8
    WritePtrs:    066DB4D8    Fifo_Flag:    82800008
    writeHeaderPtr:    066DB4D8
Fifo10:    StartPtr:    06A6B800    ReadPtr:    06A6B870
    WritePtrs:    06A6B870    Fifo_Flag:    88800200
    writeHeaderPtr:    06A6B870
Fifo11:    StartPtr:    066C8F00    ReadPtr:    066C8F00
    WritePtrs:    066C8F00    Fifo_Flag:    86800080
    writeHeaderPtr:    066C8F00
Fifo12:    StartPtr:    06A98800    ReadPtr:    06A98B00
    WritePtrs:    06A98800    Fifo_Flag:    89000100
    writeHeaderPtr:    06A98800
Fifo13:    StartPtr:    06427880    ReadPtr:    06427880
    WritePtrs:    06427880    Fifo_Flag:    86800080
    writeHeaderPtr:    06427880
Fifo14:    StartPtr:    00000000    ReadPtr:    00000000
    WritePtrs:    00000000    Fifo_Flag:    00800000
    writeHeaderPtr:    00000000
Fifo15:    StartPtr:    06992F80    ReadPtr:    06992F90
--More--                               WritePtrs:    06992F90    Fifo_Flag:    84800020
    writeHeaderPtr:    06992F90
Complete Board Id:0x4006
RDCCI37F0#show platform port-asic stats drop
Port-asic Port Drop Statistics - Summary
  RxQueue 0 Drop Stats: 0
  RxQueue 1 Drop Stats: 0
  RxQueue 2 Drop Stats: 0
  RxQueue 3 Drop Stats: 0
  Port  0 TxQueue Drop Stats: 0
  Port  1 TxQueue Drop Stats: 0
  Port  2 TxQueue Drop Stats: 0
  Port  3 TxQueue Drop Stats: 0
  Port  4 TxQueue Drop Stats: 43101743
  Port  5 TxQueue Drop Stats: 23173181
  Port  6 TxQueue Drop Stats: 159216307
  Port  7 TxQueue Drop Stats: 0
  Port  8 TxQueue Drop Stats: 79275931
  Port  9 TxQueue Drop Stats: 159240537
  Port 10 TxQueue Drop Stats: 0
  Port 11 TxQueue Drop Stats: 65443677
  Port 12 TxQueue Drop Stats: 43845906
  Port 13 TxQueue Drop Stats: 0
  Port 14 TxQueue Drop Stats: 0
  Port 15 TxQueue Drop Stats: 23250063
  Port 16 TxQueue Drop Stats: 23113365
  Port 17 TxQueue Drop Stats: 79946637
  Port 18 TxQueue Drop Stats: 16162287
  Port 19 TxQueue Drop Stats: 0
  Port 20 TxQueue Drop Stats: 23124609
  Port 21 TxQueue Drop Stats: 0
  Port 22 TxQueue Drop Stats: 23080029
  Port 23 TxQueue Drop Stats: 0
  Port 24 TxQueue Drop Stats: 23078915
  Port 25 TxQueue Drop Stats: 0
  Supervisor TxQueue Drop Statistics
    Queue  0: 0
    Queue  1: 0
    Queue  2: 0
    Queue  3: 105753
    Queue  4: 0
    Queue  5: 0
    Queue  6: 0
    Queue  7: 20877
    Queue  8: 150143
    Queue  9: 0
--More--                               Queue 10: 0
--More--                               Queue 11: 0
    Queue 12: 0
    Queue 13: 0
    Queue 14: 0
    Queue 15: 0
Port-asic Port Drop Statistics - Details
  RxQueue Drop Statistics
    Queue 0
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
    Queue 1
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
    Queue 2
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
    Queue 3
    Weight 0 Frames: 0
    Weight 1 Frames: 0
    Weight 2 Frames: 0
  Port 0 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 1 TxQueue Drop Statistics
    Queue 0
--More--                                 Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 2 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 3 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
--More--                                 Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 4 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 38592
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 43063151
  Port 5 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 31010
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 23142171
  Port 6 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
    Queue 1
      Weight 0 Frames 83682
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 159132625
  Port 7 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 8 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 30633
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 1 Frames 0
      Weight 2 Frames 79245298
  Port 9 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 83672
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 159156865
  Port 10 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 11 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
--More--                                 Weight 0 Frames 47446
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 65396231
  Port 12 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 38774
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 43807132
  Port 13 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
  Port 14 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 15 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 30601
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 23219462
  Port 16 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 31014
      Weight 1 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 23082351
  Port 17 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 53038
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 79893599
  Port 18 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 20670
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 16141617
--More--                             Port 19 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 20 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 31004
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 23093605
  Port 21 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 22 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 31013
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 23049016
  Port 23 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
  Port 24 TxQueue Drop Statistics
    Queue 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 31032
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 23047883
  Port 25 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue  0: 0
    Queue  1: 0
    Queue  2: 0
    Queue  3: 105753
    Queue  4: 0
    Queue  5: 0
    Queue  6: 0
    Queue  7: 20877
    Queue  8: 150143
    Queue  9: 0
    Queue 10: 0
    Queue 11: 0
--More--                               Queue 12: 0
    Queue 13: 0
    Queue 14: 0
    Queue 15: 0
RDCCI37F0#  show platform port-asic stats drop        exit
HI Aman,
I believe the switches are working fine now.
The CPU on the switches seems to be normal:
100
90
80
70
60
50
40
30
20 *                                   *****
             0    5    0    5    0    5    0    5    0    5
100
90
80                                      *
70                                      *
60                                      *
50                                      *
40                                      *
30                   * *        *       *        *      * *
             0    5    0    5    0    5    0    5    0    5
Its quite difficult to findout what causing the CPU to go high as it has drop back to normal.
I request you to kindly log a tac case when you see the CPU going high and we can look into this live and findout the rootcause.
I can recommend few steps which you can look out during the high cpu:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00807213f5.shtml
This is the one of the link which helps you to troubleshoot the high cpu.
Check the cpu utilization and findout it is due to process or interupt:
Eg: 99%11%( Were 99 is total cpu utizliation and 11 % is due to interupt and 99-11 is due to process).
2) CPU has 16 Queus on 3750 hence check which Q is punting the traffic (show controllers cpu-interface- under this command check which is hte Q value which is getting increased.)
3) look for TX Q drop which is getting increaeed under show platform port asic stats drop.
4)There is some debugs but I would suggest you do it with the TAC engineer.
Hope this helps.
REgards
Inayath
