Cisco 2960G No LANBASE-ROUTING Feature
markrebuldad
Dear Sir(s),
I need some help on one of our switches (WS-C2960G-24TC-L). When I try to turn on the lanbase-routing feature using sdm prefer lanbase-routing, it gives me an error (Unknown command). I tried "sdm prefer ?", and lanbase-routing wasn't there (only qos, default and dual IPv4 & IPv6). The switch is running on image C2960-LANBASEK9-M version 12.2(50)SE5.
We have another switch (WS-C2960S-24TS-L), running on image C2960S-UNIVERSALK9-M version 12.2(55)SE5, and I can enable lanbase-routing feature. If I upgrade the WS-C2960G-24TC-L to version 12.2(55)SE5, will it be able to do inter-vlan routing? Or is the switch itself totally limited to VLAN configuration only?
Thanks!
MARK
glen.grant
  Routing was not introduced on this box until version like 12.2.55 so upgrade and retry it .
patrick.preuss
29xx switches are Layer 2 only.
Hi Patrick,
Yes, indeed. 29xx switches are Layer 2 only, but some models in this series do have inter-vlan routing (compare LANBASE image to LANLITE images for 29xx series, so you would know the difference). Having inter-vlan routing doesnt mean to say that the switch is Layer 3. Some 2960 switches can have a number of static routes configured on them, but no dynamic routes, though. For this case, I just need the static routes, that's why I'm trying to check whether upgrading the IOS on my
WS-C2960G-24TC-L will have the inter-vlan routing feature.
glen.grant
Hi glen,
Guess I just have to try that.
