FP1010 in ASA mode trunk configuration
bruce.thornton
I have a FP 1010 running ASA mode. I need to connect the FP1010 to a cable modem for a remote site to support PC/Phones. My plan is to configure a trunk on the inside interface of the FP 1010 and connect that to a trunk port on a Cisco switch to pass 2 vlans, (data/voice). My question is does teh FP1010 in ASA mode support this configuration? If yes config example please.
balaji.bandi
If this is ASA code running, we should use same ASA config as example below :  (hope is this what you looking if not please explain?)
https://www.petenetlive.com/KB/Article/0001085
On switch side you make a Trunk port and allow respected VLAN in theTrunk. (bottom onf the page there is link, if you click you get switch trunk example)
BB
