frame relay
cisco steps
I am trying to set a frame relay lab so I can create the cloud and proceed with my BCSI exam training. I have
2 x 2610 with 2 serial interfaces
1 x 2510 w/ 2 serial interfaces
2 x 2900 XL switches
Please help
23 Replies 23
Giuseppe Larosa
Hello ocporbust,
I would look for a 2500 with more serial interfaces to be used as FR switch. This would allow you to have three FR DTE routers and to emulate all the terrible NBMA issues with EIGRP, OSPF and RIP.
To be noted that you can use A/S interfaces with the only limit that when used in sync mode they cannot go faster then 128 kbps: it is enough to configure accordingly the other sides.
For each connection you need a V.35 DTE and a V.35 DCE cable or the equivalent composite cable.
for FR switching see
http://www.cisco.com/en/US/docs/ios/wan/configuration/guide/wan_cfg_frm_rly_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1055601
Hope to help
Giuseppe
Giuseppe Thanks for the link, is there anyway you can help with the physical setup..
I have 3 router each w/ 2 serial interfaces, I have 3 DCE/DTE cables.
where so I start as far as cabling.
here is what I did so far. I connected
r1--s0---DCE to r2--s0--DTE
r1--S1---DCE to r3--s1--DTE
is this how its suppose too
Hello Octorbust,
the setup is correct.
You need to configure the clock rate command on the side where the DCE cable is connected.
you can check this with
sh controller ser x/y
it will say DTE cable detected or DCE cable detected.
To be noted that OSI L1 DCE and FR L2 DCE can be on the two different sides but for clarity it is usually DCE cable on the FR switch side.
Hope to help
Giuseppe
Thanks Giuseppe ,
what I need now is to configure the router to create the cloud,
I spent 2 days trying to create but no success. Can you help or provide a config example to do that
.. Gracias
Thank you so much Edison..
still no go, here is my config based on the link provided.
R3#sho run
Building configuration...
Current configuration:
version 11.0
service udp-small-servers
service tcp-small-servers
hostname R3
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
encapsulation frame-relay
no fair-queue
clockrate 64000
interface Serial0.1 point-to-point
ip address 10.23.23.3 255.255.255.0
frame-relay interface-dlci 232
interface Serial1
no ip address
no keepalive
shutdown
clockrate 64000
interface Serial1.1 point-to-point
ip address 10.33.13.3 255.255.255.0
frame-relay interface-dlci 131
line con 0
line aux 0
transport input all
line vty 0 4
login
end
R2#sho run
Current configuration : 682 bytes
version 12.3
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
interface Ethernet0/0
no ip address
shutdown
half-duplex
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
interface Serial0/1.1 point-to-point
ip address 10.23.23.2 255.255.255.0
ip http server
no ip http secure-server
ip classless
line con 0
line aux 0
line vty 0 4
end
R1#sho run
Current configuration : 720 bytes
version 12.3
hostname R1
boot-start-marker
boot-end-marker
memory-size iomem 15
no aaa new-model
ip subnet-zero
ip cef
no ip address
shutdown
half-duplex
interface Serial0/0
no ip address
no keepalive
interface Serial0/0.1 point-to-point
ip address 10.13.13.1 255.255.255.0
interface Serial0/1
no ip address
shutdown
no ip http server
ip classless
line con 0
line aux 0
line vty 0 4
end
more info:
3#sho ip int b
Ethernet0 unassigned YES not set administratively down down
Serial0 unassigned YES not set up down
Serial0.1 10.23.23.3 YES manual down down
Serial1 unassigned YES not set up up
Serial1.1 10.33.13.3 YES manual up up
here is also some more info that may make a since...
R1#sho frame-relay pvc 131
PVC Statistics for interface Serial0/0 (Frame Relay DTE)
DLCI = 131, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE = Serial0/0.1
input pkts 0 output pkts 70 in bytes 0
out bytes 23870 dropped pkts 0 in pkts dropped 0
out pkts dropped 0 out bytes dropped 0
in FECN pkts 0 in BECN pkts 0 out FECN pkts 0
out BECN pkts 0 in DE pkts 0 out DE pkts 0
out bcast pkts 70 out bcast bytes 23870
pvc create time 01:36:26, last time pvc status changed 01:07:18
R2#sho frame-relay pvc 232
DLCI = 232, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE = Serial0/0.1
input pkts 0 output pkts 23 in bytes 0
out bytes 6658 dropped pkts 0 in pkts dropped 0
out bcast pkts 18 out bcast bytes 6138
pvc create time 00:17:56, last time pvc status changed 00:16:00
R2#sho frame-relay map
Serial0/0.1 (up): point-to-point dlci, dlci 232(0xE8,0x3880), broadcast
R2#sho frame-relay lmi
R1#sho frame-relay map
Serial0/0.1 (up): point-to-point dlci, dlci 131(0x83,0x2030), broadcast
I made some changes ,, and if you look @ my troubleshooting .. I was able to get all the interfaces UP/UP , the only thing that I suspect is that both PVC STATUS= STATIC.. per my notes one should be STATIC and the other should be ACTIVE..
Thanks and I hope this is not too much of the info.
it seems that you want R3 to be the FR Switch, do the following config changes:
erase the entire config on R3 and enter the following:
frame-relay switching
int s0
description R1
clockrate 64000
no shut
frame-relay intf-type dce
frame-relay route 131 interface Serial1 232
int s1
description R2
clockrate 64000
no shut
frame-relay route 232 interface Serial0 131
On R2
no ip address 10.23.23.2 255.255.255.0
ip address 10.13.13.2 255.255.255.0
Edison ,
something is still wrong.. there is no communication , I have up /up on all interfaces...
R2
interface Serial0/0
no ip address
no keepalive
R3
interface Serial0
description R1
no ip address
no fair-queue
clockrate 64000
interface Serial1
description R2
no ip address
clockrate 64000
R1
interface Serial0/0
no ip address
no keepalive
R3(config)#frame-relay switching
R3(config)#
R3(config)#int s0
R3(config-if)#description R1
R3(config-if)#clockrate 64000
R3(config-if)#no shut
R3(config-if)#frame-relay intf-type dce
%Serial0 :Frame Relay not configured on interface
R3(config-if)#frame-relay route 131 interface Serial1 232
I get this error !!!!!!!
