frame relay
cisco steps
I am trying to set a frame relay lab so I can create the cloud and proceed with my BCSI exam training. I have
2 x 2610 with 2 serial interfaces
1 x 2510 w/ 2 serial interfaces
2 x 2900 XL switches
Please help
23 Replies 23
Hello Octoirbust,
do
conf t
frame-rel switching
int ser0
enc frame-relay
frame-relay intf-type dce
frame-relay route 131 interface Serial1 232
Hope to help
Giuseppe
Giuseppe ,
I changed my config so many times that I am lost right now.
can you pls help w/ full config for r1 , r2 and r3 ..can do it anymore.. I just get more confuse.
here is my current config
r1
interface Serial0/0
ip address 192.168.10.5 255.255.255.252
encapsulation frame-relay
no keepalive
serial restart-delay 0
frame-relay interface-dlci 103
r3
interface Serial0
ip address 192.168.10.6 255.255.255.252
no keepalive
no fair-queue
r2
interface Serial0/0
ip address 192.168.10.10 255.255.255.252
no keepalive
fair-queue
frame-relay interface-dlci 203
r3
interface Serial1
ip address 192.168.10.9 255.255.255.252
no keepalive
I forgot to include encapsulation frame-relay in my previous post, my apologies - I was doing the commands from the top of my head.
Can you please go back to that config and include that command as well on R3?
It should work and R3 will become your FR Switch device.
Using R3 as the FR Switch, and not being too sure of what the author was actually trying to do, here are my working configs below. From R1 I can ping R3 and vica versa. I used Cisco NetLabs for this fyi, so I couldnt change the cables, hence the DCE config on the FR switch and the clockrate on the R2 sw. And my ports changed alittle bit. I forgot one thing, why from R1 can I not ping R1? Would I need a fr map statement?
R1#ping 10.13.13.2
Sending 5, 100-byte ICMP Echos to 10.13.13.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/56/56 ms
R1#sh run
Building configuration...
Current configuration : 933 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 15
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Serial0/1
ip address 10.13.13.1 255.255.255.0
frame-relay interface-dlci 131
interface Ethernet1/0
no ip address
shutdown
half-duplex
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
R2#ping 10.13.13.1
Sending 5, 100-byte ICMP Echos to 10.13.13.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/56/60 ms
R2#sh run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip cef
no ip domain lookup
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface Serial0/1
ip address 10.13.13.2 255.255.255.0
clock rate 64000
frame-relay interface-dlci 232
no ip address
shutdown
half-duplex
ip http server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
R3 configs in next post, this one too long.
R3#sh frame-relay rou
Input Intf Input Dlci Output Intf Output Dlci Status
Serial0/0 131 Serial0/1 232 active
Serial0/1 232 Serial0/0 131 active
R3#sh run
Current configuration : 1227 bytes
version 12.4
service udp-small-servers
service tcp-small-servers
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
frame-relay switching
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
description R1
no ip address
no fair-queue
clock rate 64000
frame-relay route 131 interface Serial0/1 232
interface Serial0/1
description R2
no ip address
no fair-queue
frame-relay route 232 interface Serial0/0 131
no ip address
shutdown
half-duplex
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
transport input all
line vty 0 4
login
end
R3#
In order to ping the serial interface of R1 from R1, you need a frame-relay map statement pointing to the remote DLCI or you can use subinterfaces.
When pinging the local serial, the packet actually tries to exit the interface and since there isn't any mapping for that IP, it fails.
HTH,
__
Edison.
Got it, thank you.
ok , Thank you all for your help. got the frame-relay up and running,
