Get IP source for a specific destionation
subalexandru
I would like to monitor on LAN what IP address is accessing SQL server.
Can someone share with me some methods or tools?
there are numerous (free) network monitoring tools available. the list below could get you started:
https://techtalk.gfi.com/the-top-20-free-network-monitoring-and-analysis-tools-for-sys-admins/
balaji.bandi
What kind of Switch you have ? you can use Wireshark to capture the traffic.
if you looking longer solution, Span/ Mirror the traffic for later analysis.
easy guide :
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-switches/940-cisco-switches-span-monitoring.html
BB
Dennis Mink
put an access list on the switch permitting traffic from any to your SQL server host IP and log the entry
Please remember to rate useful posts, by clicking on the stars below.
pieterh
you can use a lot of external tools,
but integrated in many OS is "netstat-n" and search/filter on SQL-server ports
