GLBP & vPC's - How?
aLeffingwell
Level 2
Level 2
Hey All,
I have no hands on experience with GLBP / vPC's but am learning about them now.  If I make a vPC which terminates upstream into two routers in the same GLBP group.. won't the downstream devices show multiple MAC-addresses for the same IP in their ARP table?  Wondering how the downstream devices handle this.  Thanks in advance!
Kindest Regards,
Alan
pille1234
Level 7
Level 7
I don't know what makes you think there would be a problem.
When you have 2 routers you actually need 2 vPCs, connecting each Nexus to each router
R1            R2
(|   \)      (/ |)             => vPC1 connecting R1 to N1&N2
|      \    /   |               => vPC2 connecting R2 to N1&N2
|        X     |
N1=====N2
Logically this is nothing different than that:
R1     R2
NEXUS
Now the server connected to the Nexus switches arps for the Gateway MAC and receives one virtual MAC-Adress from the AVG Router.
I'm not sure if this does answer your question though.
