GLC-TE SFP not working in CIsco nexus 3064 switch
PdhineshK
Hi Team,
Recently we have purchased the GLC-TE SFP from the Cisco team.We tried to connect those SFP's not working in our Cisco nexus switch but the same we have few old GLC-TE SFP tested on the same port its working so no issue in the switch port side.
Below are the output we are getting for the new SFPs switch running on IOS 5.0(3).
Need your valuable inputs on this to fix this issue.
sh int eth1/11 transceiver
Ethernet1/11
transceiver is present
type is 1000base-T
name is --
part number is
revision is --
serial number is -577400ARRZ--CSS
nominal bitrate is 0 MBit/sec
Link length supported for 50/125um fiber is 130 m
Link length supported for 62.5/125um fiber is 10 m
Link length supported for copper is 13 m
cisco id is --
cisco extended id number is 3
Ethernet1/11
type is 1000base-(unknown)
name is --
part number is CIISSCCOO
revision is
serial number is
nominal bitrate is 800 MBit/sec
cisco id is --
17 Replies 17
I don't see the GLC-TE, in the attached compatibility matrix (Table 3), only the GLC-T...
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/data_sheet_c78-651097.html
Thats the case (Y)
I have few SFP's GLC-TE which is working in the same switch
Cisco Nexus 3000 Series
GLC-TE is supported on Nexus-3064 from software version NX-OS 6.0(2)U3(1). Cisco Transceiver Modules Compatibility Information has frequent updates.
Thanks for the information.
But I have one GLC-TE is connected in same 3064 switch and it's working.
Is the following output from the Old GLC-TE SFP ?
Ethernet1/11
type is 1000base-T
name is --
part number is
revision is --
cisco id is --
No its new SFP which we recently purchased from Cisco
Could you please share the output from following command for both Working and non working SFPs on the nexus.
Show interface ethernet X/X Transceiver details
Hi ,
Please find the below output for working one. Non-working one will get you shortly.
sh int eth1/16 transceiver details
Ethernet1/16
type is 1000base-T
name is CISCO-AVAGO
part number is ABCU-5710RZ-CS5
revision is B2
serial number is AGM194744MC
nominal bitrate is 1300 MBit/sec
Link length supported for copper is 100 m
cisco id is --
cisco extended id number is 4
Calibration info not available
check if your Nexus supports the command:
NEXUS3064(config)# service unsupported-transceiver
Let me chk this command.
What is the purpose of this command and what would be the impact if we apply this command??
The command allows for transceivers that are not recognized to be...recognized; it works sometimes, but I am not sure it is supported on the Nexus at all....
I have tried to apply the below command but not accepting let me know how to fix this issue.
Did you get the same output for the non-working one ?
