GLC-TE SFP not working in CIsco nexus 3064 switch
PdhineshK
Hi Team,
Recently we have purchased the GLC-TE SFP from the Cisco team.We tried to connect those SFP's not working in our Cisco nexus switch but the same we have few old GLC-TE SFP tested on the same port its working so no issue in the switch port side.
Below are the output we are getting for the new SFPs switch running on IOS 5.0(3).
Need your valuable inputs on this to fix this issue.
sh int eth1/11 transceiver
Ethernet1/11
transceiver is present
type is 1000base-T
name is --
part number is
revision is --
serial number is -577400ARRZ--CSS
nominal bitrate is 0 MBit/sec
Link length supported for 50/125um fiber is 130 m
Link length supported for 62.5/125um fiber is 10 m
Link length supported for copper is 13 m
cisco id is --
cisco extended id number is 3
Ethernet1/11
type is 1000base-(unknown)
name is --
part number is CIISSCCOO
revision is
serial number is
nominal bitrate is 800 MBit/sec
cisco id is --
17 Replies 17
Give me some time I will share the output of non-working one
Hi Syed,
Please find below the output from non-working one.
sh int eth1/27 transceiver details
Ethernet1/27
    name is --
    revision is
    serial number is
    cisco id is --
    cisco extended id number is 4
           Transceiver Detail Diagnostics Information (internal calibration)
                Current              Alarms                  Warnings
                Measurement     High        Low         High          Low
  Temperature   48.25 C         2.01 C      4.00 C      0.00 C        0.00 C
  Voltage        1.67 V  ++     0.00 V      0.00 V      0.20 V        0.00 V
  Current       42.16 mA  ++    0.00 mA     0.00 mA     0.00 mA       0.53 mA
 Tx Power        3.63 dBm ++   -4.78 dBm     N/A         N/A           N/A
  Rx Power        0.63 dBm        N/A      -20.00 dBm    4.08 dBm    -22.21 dBm
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
  *** Transceiver diagnostics data may be invalid!  ***
Hi PdhineshK,
Referring to the outputs from both working and non-working SFPs, you may notice that the part no. for both the SFPs are different along with the nominal bitrate.
This clarifies that both the SFPs are not same and this could be verified by the Model no against the compatibility matrix.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-3000-series-switches/data_sheet_c78-651097.html
Outputs were requested for this specific clarification.
Hope this helps.
Best Regards
