GUI Tools for Switchport Configurations?
jameskuder
We would like to have our first level support handle the changing of switchports between vlans when requested by a user, but do not want the performing via the CLI. Is ther anything out there that would allow them to do this via a GUI interace that is very simple as well as give us the ability to lock it down to specific comands  and ports?
7 Replies 7
Eehab Suliman
what platform? Are these Catalyst Express 500 Series Switches, 2960s or some other switch family
Catalyst 3750's
courageux
You can use Network Asistant to mange the 3750s using a GUI. Check this out ....
http://www.cisco.com/en/US/products/ps5931/index.html
Its free as well
Which verision do you recommend and can you lock things down to specific ports/commands that they can run?
To be honest, I haven't really used it much so I wouldn't be able to comment on lockdown part. I think, 5.6 has some improvements over the previouus version.
Here is the link that could be helpful ....
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps5931/prod_white_paper0900aecd802d1b95.html
I installed this but it does not appear to do what I am looking for. It also requires that you have level 15 access which our Tier 1 would not have. Thanks for trying..
Jim
glen.grant
   If the switches were loaded with the .tar files you can setup the switches so they can be accessed via a browser  via http or https .  I don't know what you can  and can't do with the browser but I imagine you can modify switchports with it .
