Hello. is there a way to get 24 logs on a cisco switch port?
hamsini0992
Is there a way to get 24 hour logs on a switch port?. I had been doing something like sh log | i month date. I need a way to checking 24 hours logs every day.
11 Replies 11
Leo Laohoo
Syslog
Thank you for your reply. Is there any other way to get the logs through a command in cisco?
Default log buffer is only 4096.  Increase that value to, say, 409600.
Thank you for your reply. Can I try anything like sh log i <interface_name | i May 13 | i May 14. Will this give me logs of two dates?
@hamsini0992
check below post.
https://superuser.com/questions/995051/cisco-show-logging-command-filtered-by-specific-date
Good luck
KB
How many ports are you trying to "target"?
If there is only one port, I have a very simple idea:  Disable interface port logging except for the one target port.
Thank you for the response. I am trying to look for specific patterns in an interface. I want to track this down status over a  period of 24 hours without any syslogs. If I do only May 13, it will fetch me the result only for May 13. But I want to look for pattern for the last 24 hours.
eg., sh log | count May 13.*"***DOWN*** <interface_name>
Is there any way, I could give from and to dates
eg, sh log | count May 13.*"***DOWN*** <interface_name> ..(May 14) - Like between May 13 and May 14
I tried doing something like
sh log | count May 13.*"***DOWN*** <interface_name> | count May 14.*"***DOWN*** <interface_name> . But this gave me 0 matches.
How many ports?
Per switch one interface. There are more than 2000 switches
One port only?
Disable link logging to every ports except this one.
balaji.bandi
If you have more than 2000 switches, I suggest having SYSLOG Server and Role over the Syslog every 24 hours for each device, From all devices send interface activity logs to the Syslog server.  Write a small script (your own comfort programming, I prefer Python here) . grep all the Logs, (if the interface number matches in the Log, extract the Logs stored in a database or CSV format. you can extract reports based on the data collected in due course of time.
BB
