Help about 300 serie switches
rdrisaldi
Beginner
Beginner
I have to use 9 Cisco 300 serie switches to build a new network. I will use one of them (core switch) in L3 for routing between Vlans (3 Vlans) and the others in L2. Is there a software to centralized all switches configuration, operation and monitoring? Thanks in advance for your help.
acampbell
Advocate
Advocate
No -- these switches are not stacked, therfore they all have there own firmware/software & config individually
This link will be helpful to you as this is the 300 switch page
http://www.cisco.com/en/US/products/ps10898/tsd_products_support_series_home.html
The install pdf is
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
The config pdf
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
They configure either from a browser or good old IOS type commands
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
acampbell
Advocate
Advocate
The install pdf is
The config pdf
Alex
Recognize Your Peers
