Help Configure Cisco 1941 Router
prompt2k2
Help!!!
I just bought a cisco 1941 router, I understand it came with the Cisco CP, but I don't know how to get to that part where I can use it.
Also, how can I connect to the router directly without using the HyperTerminal console, all I want to be able to do is configure the ISP IP address and my IP address so I can use it for internet browsing.
Please help.
48 Replies 48
UPdated COnfiguration
income#sh run
Building configuration...
Current configuration : 3488 bytes
! Last configuration change at 08:25:26 UTC Mon Oct 8 2012
! NVRAM config last updated at 08:23:49 UTC Mon Oct 8 2012
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname income
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 $1$K/Wt$MOaWnBNOE9rLay.m8Sh4a.
--More--
income#sh run
version 15.1
no service pad
hostname income
boot-start-marker
boot-end-marker
enable password 7 151B050F0B272E76
aaa new-model
aaa authentication login default none
aaa authentication enable default none
aaa authentication ppp default none
aaa session-id common
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.39
ip dhcp pool users
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 217.117.0.38 10.10.10.244
no ip bootp server
ip domain name incomeelectrix
ip name-server 217.117.0.38
ip name-server 10.10.10.244
license udi pid CISCO1941/K9 sn FCZ1633716L
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
username income privilege 15 secret 4 HSyp0yWKpXLGNBvuMAwswNaIjZOwIZdQsd4T3M2hSo
A
redundancy
ip tcp synwait-time 10
class-map match-any BLOCKED
match protocol http host "*facebook.com"
match protocol http host "*youtube.com"
policy-map BLOCK
class BLOCKED
  drop
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
interface GigabitEthernet0/0
description $ES_LAN$$ETH-LAN$
ip address 10.10.10.1 255.255.255.0
ip helper-address 10.10.10.1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
service-policy input BLOCK
interface GigabitEthernet0/1
description $ES_WAN$$ETH-WAN$
ip address 41.75.205.190 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
no mop enabled
router eigrp 109
network 10.0.0.0
network 41.0.0.0
router rip
version 2
network 10.0.0.0
network 41.0.0.0
no auto-summary
ip default-gateway 41.75.205.189
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool overld 41.75.205.190 41.75.205.190 prefix-length 24
ip nat inside source list 7 pool overld overload
ip route 0.0.0.0 0.0.0.0 41.75.205.189
logging trap debugging
access-list 7 permit 10.10.10.0 0.0.0.255
access-list 199 permit icmp any any
no cdp run
snmp-server community public RO
control-plane
banner login ^CWelcome to Incomeelectrix.^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
password 7 11001706181F0E5D
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
end
income#
Hi Alain,
Been a while, how are you doing, what could be wrong with what I have down here.
IncomeElectrix#sh run
Current configuration : 4060 bytes
! Last configuration change at 07:20:49 UTC Mon Mar 10 2014 by income2
version 15.2
hostname IncomeElectrix
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 25
ip cef
no ip dhcp conflict logging
ip dhcp pool 1
 import all
 domain-name incomeelectrix.com
 dns-server 62.173.37.133 62.173.34.222
ip dhcp pool pool1
 dns-server 62.173.37.133 62.173.34.222 10.10.10.99
no ip domain lookup
ip domain name incomeelectrix.local
ip name-server 62.173.37.133
ip name-server 62.173.34.222
no ipv6 cef
crypto pki trustpoint TP-self-signed-1737792747
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1737792747
 revocation-check none
 rsakeypair TP-self-signed-1737792747
crypto pki certificate chain TP-self-signed-1737792747
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31373337 37393237 3437301E 170D3134 30313331 30393531
  33325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37333737
  39323734 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100EE53 1EF13B55 F6904BD5 DA05717A C27B7761 A54BECA7 3DDE41CC 09E56E00
  AFED14C3 B19B4457 C29E59FA 9A69632C 6C0589AB 5EA8709D 247D5619 99305911
  51E5A169 AC49A967 A55E14E9 5A6F0727 745AC8E4 679379B3 4E826FD1 681D2251
  3324F26C AC5B3E35 4E010029 23735B94 16D0DAA0 7F1F26D3 A877DBB1 6477F625
  CAFF0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14D09707 EDBAB165 3126BFDF 2DC19049 9CFCB330 02301D06
  03551D0E 04160414 D09707ED BAB16531 26BFDF2D C190499C FCB33002 300D0609
  2A864886 F70D0101 05050003 8181000F 5D9FF091 8FFA3E8E 5D329370 ED9FF358
  9128420D 896708DD D7F26CEC 9FF04805 5C685571 7C7BD0EF 07E96501 88F20439
  172756E0 5EF05994 FDF13058 EA28BC87 534C5AF0 A719BC74 6345F831 51F6EDC8
  13DBDBA1 F564A121 3AA9DC6A 6BF4969F 8E768C20 5CFEC162 D1FE91C2 B4C1EB7A
  60FA85A2 63683A97 42D957DD 77F861
        quit
license udi pid CISCO1941/K9 sn FCZ1805C4XJ
username income2 privilege 15 secret 4 5TjUzkJSiV6fGySlFYEn3g4Ob8NDebJe4GHARoR7I1o
interface Loopback0
 no ip address
 ip nat outside
 no ip address
 shutdown
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 duplex auto
 speed auto
 description This is the WAN Interface
 ip address 41.184.209.6 255.255.255.252
 duplex auto
 speed auto
interface Virtual-Template1
 ip unnumbered Loopback0
 ip nat outside
router eigrp 109
 network 10.0.0.0
 network 41.0.0.0
router rip
 version 2
 network 10.0.0.0
 network 41.0.0.0
 no auto-summary
ip default-gateway 10.10.10.1
ip http server
ip http access-class 23
ip route 0.0.0.0 0.0.0.0 41.184.205.5
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
line con 0
 login local
line aux 0
line 2
 no exec
 stopbits 1
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
line vty 5 15
 access-class 23 in
 privilege level 15
 login local
end
I agree that this very basic instruction is missing from any intial setup material that a new user sees.
Thank you for your assistance from me as well.
Using 2901 router as a newbie.
Hello
dear sir
i need to configure cisco router 1941
please help me
mizanul hoque
bangladesh
01877701666
