Help! DHCP issues
khickey6
Under the Shows router at the bottom I seem to be having issues. I can not ping the router from the laptops and can not successfully assign DHCP to those devices either. Please help!
luis_cordova
Two mistakes
1- The upstream interface is wrong.
Switch the serial cable to interface 0/3/0 of the Show router and power up the interface.
2- On the switch connected to the Show router, you must leave the f0/1 interface in trunk mode.
After these 2 changes, the PCs get addressing.
jamesbos96602
u did not change vlan right still on vlan 1
on swich port u need  make ip access-list for dhcp in bouth directions
and swichport mode access
on all ports
this should fix the probem
Hello
See attached working PT file, the issue you had was that the last rtrs serial interface was not working correctly so that was changed and also the switch interface connecting to the last router required to be trunked, lastly on all of the rtrs, I disabled auto summarization and enabled rip version 2.
Kind Regards
Paul
