Help for an ACL
Clem58
Level 3
Level 3
I have created an ACL for a VLAN, we need it to block access to RFC1918 subnets, excepting for one DHCP server.
So I have created that ACL:
ip access-list extended Voice_VLAN_36
10 permit udp any host 192.168.4.115 eq bootps
20 permit udp any host 192.168.4.115 eq bootpc
30 deny ip any 10.0.0.0 0.255.255.255
40 deny ip any 172.0.0.0 0.15.255.255
50 deny ip any 192.168.0.0 0.0.255.255
60 permit ip any any
Then I have assigned this ACL to the VLAN like this:
Interface VLAN36
ip access-group Voice_VLAN_36 in
I have applied this ACL on 1 C9300 core switch, and 3 C3850.
It's working on the C9300 and one C3850, devices does not have internet on the other 2 C3850.
Could you please help me finding what's wrong ?
Thanks by advance.
9 Replies 9
This issue not relate to ACL I think
You have missing in SW or not allow voice vlan 36 in trunk of SW
Check
Show vlan breif
Show interface trunk
Check if vlan 36 is appear or not
MHM
Everything is correctly setup in the switch, if I remove the ACL statement from the VLAN SVI, it's working fine.
5 permit udp any eq bootpc any eq bootps <<- add this to make sure the workstation get correct IP or not
10 permit udp any host 192.168.4.115 eq bootps <<- remove this
20 permit udp any host 192.168.4.115 eq bootpc <<- remove this
70 deny ip any any Log <<- add this to see log if the ACL drop the packet
MHM
My first comment is that there is a flaw in your acl. You have this
which should be
40 deny ip any 172.16.0.0 0.15.255.255
Make the correction and let us know if the behavior changes. If there is still a problem then we will need more information about the switches where it does not work.
Rick
Thanks Richard, that is a great catch, I wonder how I did not see that ! I will give it a try and let you know.
You are welcome. It is an easy mistake to make.
Thanks for letting us know that you have solved the issue and that it was not a problem with the acl.
Rick
So it's working now, not thanks to the correction, but because I forgot to set external DNS in DHCP scope option, we were still using internal DNS, so that were blocked of course !
Anyway it's good to have corrected the 172.16.0.0/12 subnet !
Thanks MHM, why do yo want to remove lines 10 & 20 as we need to have access to 192.168.4.115 DHCP as an exception.
I use both ACL in one line and I specify ANY in case that the DHCP server is different that host  192.168.4.115
and use deny ip any any log to see why the ACL drop it,
I was think that you use external DNS (8.8.8.8 or 8.8.4.4 or ISP DNS) not internal
anyway glad issue solve
have nice day
MHM
