09-23-2016 07:22 AM - edited 03-08-2019 07:33 AM
Hello everyone!
I won an switch Cisco ME 3400 series for use in my little company, I began to search more about how to configure it. To test it, i plugged two PCs on it and i try to ping these PCs. The PCs have the IPs 10.0.0.2 and 10.0.0.3, respectively. But, when i do the command ping on Windows, the PCs do not communicate.
People, where i going wrong? I made this scene on Packet Tracer with Catalyst 2960 and worked it properly. On the real switch (ME 3400), I made the configuration described on the official manual, in the appendix D: "Configuring thw switch with CLI-Based setup program" , link here.
Anyone can help me? Thanks in advance!
Follows the startup-config of switch:
MySw#show startup-config
Using 1441 out of 524288 bytes
version 12.2
no service pad
hostname MySw
boot-start-marker
boot-end-marker
enable secret 5 $1$kBA1$b/6bpsukkUk4BtyQY/RoR0
enable password 1234
no aaa new-model
system mtu routing 1900
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
port-type nni
interface GigabitEthernet0/2
port-type nni
interface Vlan1
ip address 10.0.0.1 255.0.0.0
no ip route-cache
no ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
password 12345
login
line vty 5 15
password 12345
login
end
MySw#show vlan brief
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20
Fa0/21, Fa0/22, Fa0/23, Fa0/24
Gi0/1, Gi0/2
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
MySw#show ip interface brief
Vlan1 10.0.0.1 YES manual up down
FastEthernet0/1 unassigned YES unset down down
FastEthernet0/2 unassigned YES unset down down
FastEthernet0/3 unassigned YES unset down down
FastEthernet0/4 unassigned YES unset down down
FastEthernet0/5 unassigned YES unset down down
FastEthernet0/6 unassigned YES unset down down
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset down down
FastEthernet0/9 unassigned YES unset down down
FastEthernet0/10 unassigned YES unset down down
FastEthernet0/11 unassigned YES unset down down
FastEthernet0/12 unassigned YES unset down down
FastEthernet0/13 unassigned YES unset down down
FastEthernet0/14 unassigned YES unset down down
FastEthernet0/15 unassigned YES unset down down
FastEthernet0/16 unassigned YES unset down down
FastEthernet0/17 unassigned YES unset down down
FastEthernet0/18 unassigned YES unset down down
FastEthernet0/19 unassigned YES unset down down
FastEthernet0/20 unassigned YES unset down down
FastEthernet0/21 unassigned YES unset down down
FastEthernet0/22 unassigned YES unset down down
FastEthernet0/23 unassigned YES unset down down
FastEthernet0/24 unassigned YES unset down down
GigabitEthernet0/1 unassigned YES unset down down
GigabitEthernet0/2 unassigned YES unset down down
09-24-2016 05:51 AM
It is strange that the ports are down with the pcs connected. but you need to configure the port type as uni for ping to work. i always have the same problem when i get a hold of a ME switch.
You have connected the computers in the two gbit port right?
09-26-2016 07:39 AM
You have connected te computers in the two gbit port right?
My apologies, i sent my config without the rj45 cables plugged on. Follows the command "show ip interface brief" again:
MySw>show ip interface brief
Vlan1 10.0.0.1 YES NVRAM up up
FastEthernet0/1 unassigned YES unset up up
FastEthernet0/3 unassigned YES unset up up
As you suggested me, i changed the port-type to uni, using these commands:
MySw#conf t
Enter configuration commands, one per line. End with CNTL/Z.
MySw(config)#interface range fastEthernet 0/1-24
MySw(config-if-range)#port-type uni
But still I can not ping the two PCs.
When i show the running-config, the unicast port does not appear. See:
I saved these configs on startup-config, but he is really saved?
Thanks for the reply!
09-26-2016 07:53 AM
The UNI configuration is default on the FE ports.
Try connecting the computer directly with a crossover cable to see if that works?
What output does you show VLAN brief command give?
10-24-2016 12:28 PM
Thank you very much for the help buddy!
I got it ping the PCs following approximately your logic, i've change the first four FE ports to NNI-type, instead of UNI. Ok, i have to plug at least one PC on NNI port, but it already serves for my purposes.
Follows the commands for those who need:
Press RETURN to get started!
MySW#ena
MySW#conf t
MySW(config)#interface range gigabitEthernet 0/1-2
MySW(config-if-range)#port type uni
MySW#
%SYS-5-CONFIG_I: Configured from console by console
MySW#ena
MySW#conf t
MySW(config)#int range fastEthernet 0/1-4
MySW(config-if-range)#port-type nni
MySW#
wr
Building configuration...
[OK]
MySW#
