Cisco and Avaya Port-Channel Configuratuion
Greetings,
I'm in need of a some advice on setting up a port-channel from a Cisco 3750x to an Avaya switch stack.  So far, I've removed the port-channel from both trunk interfaces and left both links as just trunk.  I've asked the Avaya engineer to do the same so we can troubleshoot any errors between us.
I've asked the data center to loop up the other side and both my links come up, when they removed the loop, both links went back down.  However, the Avaya end shows up up for some reason, but my end shows down down (notconnect).  This at first sounded like the they were connecting the wrong fiber drops but that's not the case here.  I've since removed the port-channel from my trunk interfaces, removed cdp and spanning-tree.  The fiber run is a straight run, no logical media convertors in between, according to the data center techs so I'm at a loss.
Is there any caveats to this setup that I'm missing or any related articles I can reference that someone can share to help troubleshoot?
Cisco 3750 Config:
 switchport trunk allowed vlan 1102,2002,2902
 switchport mode trunk
 no cdp enable
 spanning-tree bpdufilter enable
no channel-group 2 mode on (currently removed for troubleshooting reasons)
interface Port-channel2
Thanks in advance,
Andrew
Andrew,
there is a document that describes the necessary configurations for both the 3750 and the Avaya end:
https://downloads.avaya.com/css/P8/documents/100123888
Andrew,
