[HELP] Routing and Switching Issue
fatalXerror
Level 5
Level 5
Hi Experts,
Good Day!
I need help about the routing and switching of my network since I'm more familiar about security technologies.
Technically, I have 1 ASA firewall and 2 non-stacked Catalyst below the ASA firewall. My link to the 2 non-stacked Catalysts is via port-channel that is configured from the ASA firewall and I also configured the interface of the Catalyst as a port channel. The 2 non-stacked Catalysts are running HSRP with a Virtual IP (VIP) of 10.132.253.25 however the issue is that from the ASA which I configured correctly, I cannot ping the VIP of the 2 non-stacked Catalysts but I can ping the interface vlan 20 (SVI) of each Catalysts.
How can I resolve this issue?
Below are the configuration portion of the 2 non-stacked Catalysts.
CAT1
CAT1#sh run int vlan 20
Building configuration...
Current configuration : 216 bytes
interface Vlan20
description {VPN}
ip address 10.132.253.26 255.255.255.248
ip ospf network point-to-point
ip ospf 10 area 0.0.0.0
standby 20 ip 10.132.253.25
standby 20 priority 210
standby 20 preempt
end
CAT1#sh run int gi1/7
Current configuration : 170 bytes
interface GigabitEthernet1/7
description [VPN01 PORT2]
switchport access vlan 20
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
end
CAT1#sh run int gi1/8
interface GigabitEthernet1/8
description [VPN02 PORT2]
end
CAT2
CAT2#sh run int vlan 20
Current configuration : 196 bytes
interface Vlan20
description {VPN}
ip address 10.132.253.27 255.255.255.248
standby 20 priority 115
end
CAT2#sh run int gi1/7
description [VPN01 PORT3]
end
CAT2#sh run int gi1/8
description [VPN02 PORT3]
end
ASA-1
interface GigabitEthernet0/2
 description ### Member Interface of PortChannel 20 ###
 channel-group 20 mode on
 no nameif
 no security-level
 no ip address
 no shutdown
interface GigabitEthernet0/3
 no nameif
 no security-level
 no ip address
 no shutdown
interface Port-channel20
 description ### Members: Gig0/2 and Gig0/3 ###
 lacp max-bundle 8
 no nameif
 no security-level
 no ip address
 no shutdown
interface Port-channel20.20
 vlan 20
 nameif INSIDE
 security-level 100
 ip address 10.132.253.29 255.255.255.248
 no shutdown
Please see diagram attached for your reference.
Thanks.
I think the setup is incorrect. You can't have port-channel on one side and not on the other side..
Hi ahmed,
Good Day!
Sorry I paste the incorrect configurations.
Please see below for the correct one.
CAT1
interface FastEthernet1/0
 switchport trunk allowed vlan 1,2,20,1002-1005
 switchport mode trunk
 channel-group 1 mode on
end
interface Vlan20
 description {VPN}
 standby 20 preempt
interface Port-channel1
end
CAT2
end
interface Vlan20
 description {VPN}
 standby 20 preempt
end
ASA
 no nameif
 no security-level
 no ip address
 no shutdown
 no nameif
 no security-level
 no ip address
 no shutdown
 lacp max-bundle 8
 no nameif
 no security-level
 no ip address
 no shutdown
 vlan 20
 nameif INSIDE
 security-level 100
 no shutdown
For your assistance please.
That's still invalid design. In order to be able to connect your ASA two different switches and have a single port channel that spans the two switches you will need either stacking, vPC or VSS.
