Help: subnetting
Good day,
Can u help me subnet 172.16.0.0/16 for me to have 256 networks.
What subnetworks will I have?
You are making a fundamental mistake in that to get 256 subnets in binary you only need 8 bits.
128 + 64 + 32 + 16 + 8 + 4 + 2 + 1 = 255, but what you are missing is the zero subnet which is 00000000. which gives you the 256.
So to get 256 subnets for 172.16.0.0 /16 the first would be:
172.16.0.0 /24 (Third octect being 00000000)
The next would be 172.16.1.0 /24 (Third octect being 00000001)
172.16.2.0 /24 (Third octect being 00000010)
172.16.3.0 /24 (Third octect being 00000011)
Up to 255 with 172.16.255.0 /24 (Third octect being 11111111)
So in binary 00000000 to 11111111 is 256 subnets.
6 Replies 6
Dennis Mink
how many IP addresses do you need in each subnet?
if you were to do 172.16.1.0/24-172.16.255.0/24 you have 255
if you do 172.16.1.0/25-172.16.255.0/25 you have even more
please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
Actually 172.16.1.0/24 - 172.16.255.0/24 will give you 256 subnets. (0 to 255 = 256)
(Dennis should still get the credit)
Yeah, uuuh OK, true , oops  ;-)
Hi...i see your point and thankyou. But i am wondering, Iam actually following a method of subnetting and all of the time I get the right answers through it until i encountered this problem.
It goes like this.
Given: 172.16.0.0/16
Requirement: split the given IP address to make 256 subnets.
Step 1: convert the required target subnet into binary
So: 256 is 100000000 in binary
And it takes 9 bits to get to it
Step 2: reserve the number of bits in the given IP
So: 172.16.11111111.10000000/25
Step 3: find the increment
So: 128
From the last octet:
1=128
0=64
0=32
0=16
0=8
0=4
0=2
0=1
Step 4: determine the subnets through incrementing the subnets by the "increment"
So: 1st subnet..172.16.0.0/25
       2nd subnet...172.16.0.128/25
       3rd subnet...172.168.1.0/25
      4th subnet...172.168.1.128/25
       5th subnet...172.168.2.0/25
And so on....
I realized...i will get more that 256 subnets if ifollowed my process....so where did igo wrong?
So for this particular scenario....i should make an excemption and always remember that 0 is included in the count....thankyou very much
