Help! Trying to set up VLAN across two switches and be able to ping between hosts.
The51stAgent
Hey guys. I'm still in the early stages of this stuff. I have a Cisco 1841 router double NATing from my ISP router. My 1841 router is then connected to switch 1 via Fa0/1. Switch 1 is connected to switch 2 via Fa0/13 on both switches.I trunked it. So if I have some ports set for Vlan 50 on both switches why would they not be able to ping each other? I may have some leftover configurations in these outputs but I tried to clear out everything from the messing around I did previous to this. Please let me know what I am doing wrong.This is driving me crazy. Suggestions for configs for starting anew (that would help me all the same)? All I want to do is set up a VLAN that spans across two switches and allows me to ping between hosts on that same VLAN that are connected to different switches. I am at my wits end. Also, this is not an issue of firewalls blocking the pings. I am sure of that, as I have temporarily turned them off and was able to ping in other scenarios I have set up in the past. Below are configs for Sw1 and 2.
Thank you,
Switch#show vlan brief
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/3, Fa0/4, Fa0/6
                                                Fa0/7, Fa0/8, Fa0/9, Fa0/10
                                                Fa0/11, Fa0/12, Fa0/14, Fa0/15
                                                Fa0/16, Fa0/17, Fa0/18, Fa0/19
                                                Fa0/20, Fa0/21, Fa0/22, Fa0/23
                                                Fa0/24, Gi0/1, Gi0/2
50   VLAN0050                         active    Fa0/2, Fa0/5
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Switch#
Switch#
Switch#show running-config
Building configuration...
Current configuration : 1303 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
 switchport access vlan 50
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
 switchport mode trunk
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 ip address dhcp
 no ip route-cache
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
Switch#show interfaces trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/13      on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/13      1-4094
Port        Vlans allowed and active in management domain
Fa0/13      1,50
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/13      1,50
And Switch 2:
Switch2#show running-config
Current configuration : 1495 bytes
version 12.2
no service pad
hostname Switch2
no aaa new-model
ip subnet-zero
no file verify auto
interface Port-channel1
 switchport access vlan 99
 switchport mode access
 channel-group 1 mode on
 switchport mode dynamic desirable
interface Vlan1
 no ip address
 no ip route-cache
ip http server
control-plane
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
Switch2#show interface trunk
Fa0/13      auto         802.1q         trunking      1
Fa0/13      1-4094
Fa0/13      1,50
Fa0/13      1,50
Switch2#show vlan brief
1    default                          active    Fa0/3, Fa0/4, Fa0/5, Fa0/6
                                                Fa0/20, Fa0/21, Fa0/23, Fa0/24
                                                Gi0/2
Reza Sharifi
For testing, if you are using only one vlan (50) you can but don't have to trunk the connection between the 2 switches. You can simply configure port fa0/13 on both switch as access port.
config t
int fa0/13
switchport
same on switch-2
Now if you pick a port (say fa0/1) on both switches,configure them the same as above (access port with vlan 50) and connect 2 laptops to these ports, give each laptop an IP in the same subnet, you should be able to ping between the 2 hosts.
laptop-1 port fa0/1 ip 10.10.10.2
laptop-2 port fa0/1 ip 10.10.10.3
I don't see anything in my quick perusal of your code that would suggest a lingering configuration blocking the ports from communicating with each other.
I've seen some strange things on switches before where the interfaces for the VLAN are not active and this causes issue. You could check this with "show run int vlan 50"; if it comes back saying it doesn't exist, you just create it by going into the interface (int vlan 50) and this will  create the VLAN interface and set it to Up/Up. Do it on both switches.
If that doesn't work, I would honestly start over: it's not worth the stress.
