help with /17 and /18 subnetting
Akbarayub
Dear all,
I was wondering if someone could help me with class B /17 and 18 subnetting i don't understand how the octets increment i find subnetting easy on class C now but get confuse with increments with class B. . I would appreciate if you can provide me with examples for the whole range so that i can make my own conclusions. Thanks in advance.
10 Replies 10
JohnTylerPearce
Level 7
Level 7
A /17 is using 17 bits for the network prefix, so with a class B , you are reserving one bit for the network portion 15 for host bits. So you are going to have 2 subnets and 32766 hosts if I did my math right. 184.64.0.1 - 184.64.127.254 and 184.64.128.1 - 184.64.255.254.
Sent from Cisco Technical Support Android App
Akbarayub
Thank you for the prompt response. But i thought on a /17 it increments at 128 and your example is showing 64 i think.
Your math is not correct. John is correct that a /17 would have only two subnets in which the third octet would start at 0 and increment to 128 as his post shows.
Rick
Rick
Akbarayub
Thank you for the response how do you figure out the number of hosts?
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Actually what John showed was the addresses for hosts, actual address blocks would be:
x.x.0.0/16 (x.x.0.0 - x.x.255.255)
x.x.0.0/17 (x.x.0.0 - x.x.127.255)
x.x.0.0/18 (x.x.0.0 - x.x.63.255)
x.x.64.0/18 (x.x.64.0 - x.x.127.255)
x.x.128.0/17 (x.x.128.0 - x.x.255.255)
x.x.128.0/18 (x.x.128.0 - x.x.191.255)
x.x.192.0/18 (x.x.192.0 - x.x.255.255)
Hosts are 2 to the N (host bits) - 2.  So for a /16 you have 2**16-2=65,534; for /17 2**15-2=32,766; and for /18 2**14-2=16,382
Akbarayub
Thank guys still not sure how to do class B subnetting.
You have told us that you are comfortable with subnetting of class C where the subnets are configured in the fourth octet. Subnetting with a class B is quite similar where the subnets are configured in the third octet.
Rick
Rick
Akbarayub
Dear Rick,
Thanks for the prompt response. Yeah i can easily subnet class C using the magic number method. I get all confused with class B for some strange reason. I just wanted some clear examples to help me understand it.
This works for me. I hope that it will work for you also:
! class C subnetting
mask /30  number of host bits 2 number of hosts (2^n - 2)  = 2
mask /29  number of host bits 3 number of hosts (2^n - 2)  = 6
mask /28  number of host bits 4 number of hosts (2^n - 2)  = 14
mask /27  number of host bits 5 number of hosts (2^n - 2)  = 30
mask /26  number of host bits 6 number of hosts (2^n - 2)  = 62
mask /25  number of host bits 7 number of hosts (2^n - 2)  = 126
mask /24  number of host bits 8 number of hosts (2^n - 2)  = 254
! class B subnetting
mask /23  number of host bits 9 number of hosts (2^n - 2)  = 510
mask /22  number of host bits 10 number of hosts (2^n - 2)  = 1022
mask /21  number of host bits 11 number of hosts (2^n - 2)  = 2046
mask /20  number of host bits 12 number of hosts (2^n - 2)  = 4094
mask /19  number of host bits 13 number of hosts (2^n - 2)  = 8190
mask /18  number of host bits 14 number of hosts (2^n - 2)  = 16382
mask /17  number of host bits 15 number of hosts (2^n - 2)  = 32766
mask /16  number of host bits 16 number of hosts (2^n - 2)  = 65534
Rick
Rick
Hi Akbar
There is simple rule of subnetting forgot class A,B,C. Just you need to remember the number bits you have to borrow from host part to network.
There would be 2 questions :
1. You know the host count and you need to create subnet accordingly.
For example you have 172.16.0.0/16 network and you required to create subnets so that each subnet have 500 hosts.
Answer> so for that you use the formula:      2^n-2 => 502  so from here  you need to get the value of n (where n is number of host bits)
here in our case n=9
172.16. _ _ _ _ _ _ _/ _ . _ _ _ _ _ _ _ _ :::::: So here you can see the / is distingusing the subnet or network part with host.
So the first subnetwork will be  172.16.0.0/25
First ip : 172.16.0.1
last IP : 172.16.1.254
Broadcast IP : 172.16.1.255
Hope this will help you.
