Problem with CPU on Cat 4507
Dao Quynh
Community Member
hi all,
Our Customer used Distribution switches are DistSW4507-01 and DistSW4507-02. These switches used HSRP with Dist-02 is active, Dist-01 is standby.
But, the past few days then the CPU of Dist-01 increase to 60%, you can see result as follow:
DistSW-4507-01#sh processes cpu hi
     54515 5 5 5 5 5 545 5 5 5 515 5 515 5 5 5 5 5 5 515 5 515
    9414049494949494941494949494049494049494949494949404949404
100
90
80
70
60
50  * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
40  *** * * * * * * *** * * * * * * * * * * * * * * * * * * *
30  *** * * * * * * *** * * * * * * * * * * * * * * * * * * *
20  *** * * * * * * *** * * * * * * * * * * * * * * * * * * *
10 ##########################################################
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    5555555555555555555555555555555555555555554554444445555545444444444444
    5555454554444343443332233222221211211000009009999980000090999998877787
100
90
80
70
60 **** * **
50 **********************************************************************
40 **********************************************************************
30 **********************************************************************
20 **********************************************************************
10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
DistSW-4507-01#sh processes cpu sorted
CPU utilization for five seconds: 54%/0%; one minute: 11%; five minutes: 9%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  41   263762272 258671478       1019 52.15%  8.30%  6.38%   0 Cat4k Mgmt LoPri
  40    68970600 388841616        177  2.07%  2.05%  2.05%   0 Cat4k Mgmt HiPri
  85     1575364  11474716        137  0.07%  0.02%  0.00%   0 Spanning Tree
  69          40   7066609          0  0.07%  0.00%  0.00%   0 UDLD
  82     2082608  61332016         33  0.07%  0.04%  0.03%   0 IP Input
135     1170540  54087423         21  0.07%  0.05%  0.07%   0 HSRP (Standby)
   7     5794312    955116       6066  0.00%  0.06%  0.05%   0 Check heaps
   8           0         3          0  0.00%  0.00%  0.00%   0 Pool Manager
Please help me resolve,
thank all,
Quynh
5 Replies 5
Dao Quynh
Community Member
Normal,
CPU of the Dist-01 is very low as follow:
DistSW-4507-01#sh processes cpu sorted | exclude 0.00
CPU utilization for five seconds: 6%/0%; one minute: 7%; five minutes: 8%
  41   263764144 258675016       1019  3.43%  4.46%  5.60%   0 Cat4k Mgmt LoPri
  40    68971748 388848159        177  2.15%  2.07%  2.05%   0 Cat4k Mgmt HiPri
135     1170540  54088269         21  0.07%  0.05%  0.07%   0 HSRP (Standby)
149        4660     64237         72  0.07%  0.11%  0.27%   1 Virtual Exec
  77     1652764   3311459        499  0.07%  0.09%  0.08%   0 CDP Protocol
InayathUlla Sharieff
Hi Dao,
Could you please provide me with the following outputs:
show process cpu sorted | ex 0.00%
Show platform cpu packet statistics
Show platform health | ex 0.00
Also the below link has very good document on troubleshooting high cpu on cat 4500 kindly go through the same which help you in finding the root cause:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml#tool2
Inayath
*Plz rate all usefull posts.
Mgmt High & Low priority process'' processes control plane as well as data packets that need to be software-switched or processed.Try the following.
Hardcode the L3 interfaces with the commands no ip redirect, no ip unreachable and no ip proxy-arp. It should come to normal.
--Pls rate helpful posts--
hi InayathUlla Sharieff,
These are the result of the commands:
DistSW-4507-01#show platform cpu packet statistics
Packets Dropped In Hardware By CPU Subport (txQueueNotAvail)
CPU Subport TxQueue 0       TxQueue 1       TxQueue 2       TxQueue 3
           0               0               0               0         287751
RkiosSysPacketMan:
Packet allocation falures: 0
Packet Buffer(Software Common) allocation falures: 0
Packet Buffer(Software ESMP) allocation falures: 0
Packet Buffer(Software EOBC) allocation falures: 0
IOS Packet Buffer Wrapper allocation falures: 0
Packets Dropped In Processing Overall
Total               5 sec avg 1 min avg 5 min avg 1 hour avg
                 431         0         0         0         0
Packets Dropped In Processing by CPU event
Event             Total               5 sec avg 1 min avg 5 min avg 1 hour avg
Input Acl                         420         0         0         0         0
SA Miss                             11         0         0         0         0
Packets Dropped In Processing by Priority
Priority         Total               5 sec avg 1 min avg 5 min avg 1 hour avg
Medium                             11        0         0         0         0
High                               420         0         0         0         0
Packets Dropped In Processing by Reason
Reason             Total               5 sec avg 1 min avg 5 min avg 1 hour avg
SrcAddrTableFilt                     8         0         0         0         0
L2DstDrop                             3         0         0         0         0
NoFloodPorts                        420         0         0         0         0
Total packet queues 16
Packets Received by Packet Queue
Queue                 Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Esmp                         166023605       25       18       13         6
L2/L3Control                 99934266       15         7         3         0
Host Learning                     4353         0         0         0         0
L3 Fwd Low                           9         0         0         0         0
L2 Fwd Low                     331699         0         0         0         0
L3 Rx Low                     2333469         2         0         0         0
DistSW-4507-01#show platform health | exclude 0.00
                     %CPU   %CPU   RunTimeMax   Priority Average %CPU Total
                     Target Actual Target Actual   Fg   Bg 5Sec Min Hour CPU
GalChassisVp-review   3.00   0.14     10     23 100 500   0   0   0 147:38
Lj-poll               1.00   0.02     2     0 100 500   0   0   0 27:18
StatValueMan Update   1.00   0.14     1     0 100 500   0   0   0 59:21
K2AclCamMan hw stats   3.00   0.55     10     5 100 500   0   0   0 437:25
K2AclPolicerTableMan   1.00   0.84     10     8 100 500   0   0   0 518:21
K2PortMan Review       2.00   0.87     15     10 100 500   0   1   0 1032:56
Gigaport9 Review       0.40   0.05     4     1 100 500   0   0   0 76:47
Gigaport11 Review     0.40   0.05     4     1 100 500   0   0   0 77:06
Gigaport16 Review     0.40   0.04     4     1 100 500   0   0   0 72:41
Gigaport18 Review     0.40   0.04     4     1 100 500   0   0   0 72:46
Gigaport25 Review     0.40   0.04     4     1 100 500   0   0   0 72:48
Gigaport39 Review     0.40   0.04     4     1 100 500   0   0   0 72:46
Gigaport48 Review     0.40   0.04     4     1 100 500   0   0   0 71:04
Gigaport49 Review     0.40   0.04     4     1 100 500   0   0   0 69:14
Gigaport50 Review     0.40   0.04     4     1 100 500   0   0   0 70:43
Gigaport51 Review     0.40   0.05     4     1 100 500   0   0   0 73:51
Gigaport52 Review     0.40   0.04     4      1 100 500   0   0   0 68:05
Gigaport53 Review     0.40   0.05     4     0 100 500   0   0   0 74:59
K2Fib Vrf Unpunt Rev   2.00   0.01     15     0 100 500   0   0   0 9:06
K2FibAdjMan Stats Re   2.00   0.50     10     8 100 500    0   0   0 213:07
K2FibMulticast Signa   2.00   0.04     10     1 100 500   0   0   0 39:10
K2FibPbr route map r   2.00   0.01     20     4 100 500   0   0   0 153:35
K2FibPbr consolidati   2.00   0.02     10     0 100 500   0   0   0 12:00
K2FibFlowCache flow   2.00   0.01     10     0 100 500   0   0   0 8:47
K2FibFlowCache adj r   2.00   0.01     10     0 100 500   0   0   0 8:47
K2MetStatsMan Review   2.00   0.07     5     2 100 500   0   0   0 55:00
K2QosDblMan Rate DBL   2.00   0.18     7     0 100 500   0   0   0 170:57
IrmFibThrottler Thro   2.00   0.01     7     0 100 500   0   0   0 9:00
K2 VlanStatsMan Revi   2.00   0.13     15     1 100 500   0   0   0 199:13
K2 Packet Memory Dia   2.00   0.04     15     8 100 500   0   0   0 754:50
K2 L2 Aging Table Re   2.00   0.03     20     2 100 500   0   0   0 138:37
K2NetflowMan - hw fl   5.00   0.03     20     1 100 500   0   0   0 29:32
K2PacketBufMonitor-P   1.00   2.58     10     1 100 500   2   2   1 2499:28
RkiosPortMan Port Re   2.00   0.05     12     8 100 500   0   0   0 115:32
Rkios Module State R   4.00   0.01     40     1 100 500  0   0   0 29:42
Rkios Online Diag Re   4.00   0.01     40     0 100 500   0   0   0 27:44
RkiosIpPbr IrmPort R   2.00   0.14     10     2 100 500   0   0   0 44:24
RkiosAclMan Review     3.00   0.03     30     0 100 500   0   0   0 56:38
EthHoleLinecardMan(1   1.66   0.01     10     24 100 500   0   0   0 31:04
EthHoleLinecardMan(3   1.66   0.13     10     4 100 500   0   0   0 235:10
%CPU Totals         239.93   9.50
                      Allocation ceiling       Current allocation
                       kbytes   % in use       kbytes   % in use
Linecard 1's Store       258.00       9%           24.63     100%
Linecard 3's Store       258.00       9%           24.79     100%
Linecard 4's Store       258.00     65%         168.57     100%
TSM objects           ------------------       ------------------
PacketBufRaw           25219.50     100%       25219.50     100%
PacketBufRawJumbo         732.81     25%         183.20     100%
Packet                   1158.75       2%           30.11       99%
PacketInfoItem           390.62       0%            0.01       0%
VbufNodes1600             55.75       0%           12.19       0%
VbufNodes400             292.00       0%           5.70       30%
VbufNodes64               62.00       0%           1.93       0%
MatEntryTableIterato       1.12      0%           0.03       0%
Rkios QoS ClassMaps       896.00       0%           0.02     100%
PimPhyports               882.81     25%         226.00     100%
PimPorts                 796.87     32%         255.00     100%
PimSlots                  5.00       2%           0.13     100%
PimChassis                 34.37       6%           2.14     100%
EbmPorts                 184.00     31%           57.32     100%
EbmIeNodes               536.00       0%           4.18     100%
EbmSortedHostTableIt       1.87       0%           0.05       0%
EbmSortedGroupTableI       1.75       0%           0.05       0%
IrmVrfs                   27.00       0%           0.10     100%
IrmFibAdjs               768.00       0%           0.46     100%
AclClassifier             768.00       0%           0.18     100%
AclFeature               1216.82       0%           0.42     100%
Acl                       384.00       0%           0.10     100%
AclListNode               256.00       0%           0.06     100%
AclClassifierActionL     512.00       0%           0.09     100%
CommandTables             48.00     23%           11.10     100%
K2FibVrfs                 152.00       0%           0.59     100%
K2TxPacket              384.00       0%           0.02       0%
K2TxPacketInfo           256.00       0%           0.03       0%
EbmVlanHostEntrys       3437.50       0%           2.37       94%
GalGbicEntrys             11.85       0%           0.09     100%
Event Nodes               128.00       0%           3.15       1%
Event Nodes               128.00       1%           7.15       22%
RkiosNetflowFlows       3072.00       0%           4.62       0%
TSM totals             194196.69     13%       26043.75       99%
Hi Dao,
Is the CPU high right now? When you took this output?
Inayath
