Help with port config
gavinr98
Need a little help. I currently have 2 Cisco 9500's configured in a virtual stack, with one of the ports on sw1 configured as a layer 3 port to route traffic to our FW. What I would like to do is add another port from the 2nd switch that is in the stack as an HA port in the case that something happens to sw1. How would I go about doing this?
This is the config of the port.
interface HundredGigE1/0/3
description Uplink to FW
no switchport
ip address 10.X.X.X 255.255.255.248
Thanks!
Hello @gavinr98 ,
Adding another link from the 9500 stack to your firewall is a good move, but depending on your configuration, the second link could stay un-utilised until the firs link fails. I am thinking of bundling the two links in a Etherchannel.
The configuration for the switch will be similar to this:
no switchport
channel-group 1 mode active
interface HundredGigE2/0/3
no switchport
interface Port-channel 1
This way you have the redundancy given by two links and the added bandwidth of the second link.
If the firewall is a Cisco FPR, than the the configuration steps can be found in this document: https://www.cisco.com/c/en/us/support/docs/security/firepower-ngfw/215351-configure-verify-and-troubleshoot-port.html#toc-hId-1981994155
Regards, LG
*** Please Rate All Helpful Responses ***
Thank you! I will give this a try. The connection is going to a 10GB FS switch, so hopefully it wont we an issue. We are going to split out the connections for HA to our FW's.
Richard Pidcock
Agree with @liviu.gheorghe , I would EtherChannel the interfaces.  Not sure what FW you are connecting to and what the capabilities are on that side of the connection but that will drive your decision.
Richard W. Pidcock
