Help with Various Errors on Port Channel
mctiesman
I have a port channel setup with each of the member ports reporting various errors.  Here is what I have for each port using the show int counters errors command:
Port        Align-Err     FCS-Err    Xmit-Err     Rcv-Err  UnderSize  OutDiscards
Gi1/0/1             0        1582           0        1582          0      1637667
Port      Single-Col  Multi-Col   Late-Col  Excess-Col  Carri-Sen      Runts     Giants
Gi1/0/1            0          0          0           0          0          0          0
Gi2/0/1             0        4456           0        4456          0      2704033
Gi2/0/1            0          0          0           0          0          0          0
This port channel is an uplink to another switch.  Can someone help me figure out what might be the issue in relation the errrors being displayed? Thanks!!
Regards, Mark
glen.grant
  Looks like a physical issue , try changing the media in the path between those 2 devices.  Are these gig links or lower speed ?
darren.g
Level 5
Level 5
I'm with Glen. FSC errors are Frame Check Sequence errors - these usually indicate bad cabling. if these are 1 gig ports, change your cabling to Cat5E at minimum (Cat6 is better) and check your termiantions etc if they're punch panels.
Cheers
Excellent. I figured it would be something easy. Thanks for the replys.
Regards, Mark
If Gig 1/0/1 is copper, then run a simple TDR
Post the output of the command "sh cable tdr int Gi1/0/1" if you want some assistance.
