Help with VTP configuration between two 2960 switches
Clay Plaga
Level 3
Level 3
I have just started my Cisco CCNA studies. I have a test network that consists of a domain controller, two 2960 switches, and a 2811 router.
I have connected the two switches with a optical transceiver on the sfp ports(gi0/2 respectively) and a fiber cable. I have the link configured as a trunk link. From what I can see, the trunk link is working because, both interfaces are green. I have an internet connection from my home linksys router into the 2811. I know the trunk link is working because, when I connect a laptop into the second switch that’s connected with the sfp/fiber trunk, I can connect to the internet. This is the problem. I have VTP configured both switches, one as the server, and the other as a client. On the client switch, it looks like the vlans have been replicated, but none of the interfaces have been associated with the vlans, and none of the ip addressing has been replicated. Is this normal vtp operation? Does the VTP protocol just configure the vlans themselves, and I have to manually assign the interfaces to the vlans and the ip addressing myself? I have added the show vlan and the show vtp status output from both switches. I have also added two screenshots. The switches are named:
sw1_vtpserver
sw2_vtpclient
I will provide any additional information you may need. Any assistance or advice will be appreciated. Thank you.
VLAN Name Status Ports
1 default active Fa0/14, Fa0/15, Fa0/16, Fa0/17
Fa0/18, Fa0/19, Fa0/20, Fa0/22
Fa0/23, Fa0/24, Gi0/1
5 VLAN0005 active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10
13 vlan13 active Fa0/13
20 wifi_vlan20 active Fa0/11, Fa0/12
30 wifi_vlan30 active
1002 fddi-default act/unsup
1003 trcrf-default act/unsup
1004 fddinet-default act/unsup
1005 trbrf-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
5 enet 100005 1500 - - - - - 0 0
13 enet 100013 1500 - - - - - 0 0
20 enet 100020 1500 - - - - - 0 0
sw1_VTPserver#show vtp status
VTP Version : running VTP2
Configuration Revision : 3
Maximum VLANs supported locally : 255
Number of existing VLANs : 9
VTP Operating Mode : Server
VTP Domain Name : test.net
VTP Pruning Mode : Disabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0xFA 0x2A 0x16 0x0F 0xAE 0xD4 0xF2 0x2A
Configuration last modified by 192.168.5.2 at 3-1-93 00:31:04
Local updater ID is 192.168.5.2 on interface Vl5 (lowest numbered VLAN interface found)
sw1_VTPserver#
sw1_VTPserver#show interface gi0/2 switch
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
sw1_VTPserver#
______________________________________________________________________________________________________________________
sw2_vtpclient
sw2_vtpclient>show vlan
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20
Fa0/21, Fa0/22, Fa0/23, Fa0/24
Gi0/1
5 VLAN0005 active
13 vlan13 active
30 enet 100030 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 trcrf 101003 4472 1005 3276 - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trbrf 101005 4472 - - 15 ibm - 0 0
VLAN AREHops STEHops Backup CRF
1003 7 7 off
Remote SPAN VLANs
Primary Secondary Type Ports
sw2_vtpclient>show vtp status
VTP Version capable : 1 to 3
VTP version running : 2
Device ID : 40f4.ec3b.1f80
Feature VLAN:
VTP Operating Mode : Client
0x8C 0xDC 0x1C 0x11 0xF0 0x1F 0xDD 0x92
sw2_vtpclient>show interface gi0/2 switch
Switchport: Enabled
Voice VLAN: none
Protected: false
sw2_vtpclient>
4 Accepted Solutions
AndreaTornaghi
Dear,
VTP isn't able to replicate interface assignment and ip address configuration.
VTP protocol configure from server to client only VLAN ID and VLAN NAME.
So for sure you must configure on every switch VLAN assignment on each interface and ip address.
luis_cordova
Hi @Clay Plaga ,
As indicated by @AndreaTornaghi , this protocol only distributes the vlan created on the server switch.
Check this guide for more details:
https://www.cisco.com/c/en/us/support/docs/lan-switching/vtp/10558-21.html
VLAN Trunk Protocol (VTP) reduces administration in a switched network. When you configure a new VLAN on one VTP server, the VLAN is distributed through all switches in the domain. This reduces the need to configure the same VLAN everywhere. VTP is a Cisco-proprietary protocol that is available on most of the Cisco Catalyst series products.
@luis_cordova, please mark as the solution my post.
Andrea
Hi @AndreaTornaghi ,
Nice to greet you.
Only the author of the post can mark as solved the answer that has helped him with his doubt.
5 Replies 5
AndreaTornaghi
Dear,
Thank you for the information. Yes, late last night when I was thinking about the configuration, I came to the conclusion that the protocol only propagates the vlans themselves.
luis_cordova
Hi @Clay Plaga ,
Andrea
Nice to greet you.
