HIGH CPU on 3560 L2
Steve Coady
OUTSIDE-DIST#sh proc cpu | ex 0.0
Core 0: CPU utilization for five seconds: 85%; one minute: 86%; five minutes: 88%
Core 1: CPU utilization for five seconds: 83%; one minute: 93%; five minutes: 83%
Core 2: CPU utilization for five seconds: 100%; one minute: 94%; five minutes: 83%
Core 3: CPU utilization for five seconds: 43%; one minute: 36%; five minutes: 54%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
5673 4265548 378885900 7185 24.7 24.6 24.6 0 stack-mgr
6203 2759041 271351187 3285 0.39 0.24 0.23 0 pdsd
10145 2526533 613459530 110 2.56 1.71 1.94 0 iosd
I need assistance determining why this is occurring.
The switch/os are "old"
    OUTSIDE-DIST uptime is 5 years, 17 weeks, 4 days, 9 minutes
    cat3k_caa-universalk9
sMc
2 Accepted Solutions
Is this a stack of 2 3650s? because the post title is:
"HIGH CPU on 3560 L2" and also in this line
The topo is:  Internet->ASR->(3560 switch) ASA->Core switches->LAN
you still have 3560.
This was confusing, as I have never seen an old 3560 with 4 core CPUs.
Anyway, both the Cisco Webex and MS Team are cloud-based solutions. If you have a SIP trunk with a provider, you may want to check and make sure you have no audio issues with them. Also, was this working before?  Did anyone make any changes to the switch or other devices especially QoS, configs? We had so many issues with Webex and had to switch to Zoom to stop the complaints about audio delays. Don't use Team much but I hear it is pretty solid. Anyway, if you think the problem is in the 3650s, in a maintenance window you can reboot the stack and see if the problem disappears.
6 Replies 6
balaji.bandi
5 years too big uptime required to reboot and check
also post show version to see any bugs.
BB
Thank you Balaji
OUTSIDE-DIST#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.05SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 30-Oct-14 13:12 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
OUTSIDE-DIST uptime is 5 years, 17 weeks, 4 days, 1 hour, 47 minutes
Uptime for this control processor is 5 years, 17 weeks, 4 days, 1 hour, 50 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Lanbase
License Type: Permanent
Next reload license Level: Lanbase
cisco WS-C3650-24TD (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
257008K bytes of Crash Files at crashinfo:.
257008K bytes of Crash Files at crashinfo-2:.
1550272K bytes of Flash at flash:.
1550272K bytes of Flash at flash-2:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of at webui:.
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24TD 03.03.05SE cat3k_caa-universalk9 INSTALL
2 28 WS-C3650-24TD 03.03.05SE cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
OUTSIDE-DIST#
sMc
Reza Sharifi
These processes are not running high for 1 min and 5 min regardless of how long the switch has been up and running.
So, it could be that the switch was always running high and you just noticed it or there is a different bug causing a high CPU.
Is this causing any production issues?
We are experiencing some issues with audio/vid during Microsoft TEAMS and Webex meetings for a large group (65) participants. Only a handful of the 65 experience problems.  The problems do occur each meeting for these (65) participants. It is not the same participants each time.
sMc
