High CPU usage caused by interrupts
diondohmen
Level 3
Level 3
Dear community.
After using my cisco 2621 as my internet gateway, and upgrading my DSL connection to 20mbit/1mbit, my cpu usage has increased to almost 90%. These 90% are reached when i am downloading @ 15mbit/sec.
After issueing a 'show proc cpu sorted' command, the 80% cpu usage was not caused by any process, but by interrupts:
CPU utilization for five seconds: 87%/81%; one minute: 1%; five minutes: 3%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
41 68700 76661 896 0.95% 0.19% 0.16% 0 IP Input
I am already using 'ip cef' on both the FA interfaces. And issueing a 'sh int stat' command result in a very healthy routing proces if you ask me, if you look at the cache/proces ratio:
FastEthernet0/0
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 75394 6417511 46889 5303988
Route cache 415701 36392514 645159 763558263
Total 491095 42810025 692048 768862251
FastEthernet0/1
Processor 16157 3375901 27213 2645817
Route cache 639952 764440471 415434 37734183
Total 656109 767816372 442647 40380000
NIDWORKR01#sh ip cef sum
IP CEF with switching (Table Version 116), flags=0x0
94 routes, 0 reresolve, 0 unresolved (0 old, 0 new), peak 0
94 leaves, 127 nodes, 144864 bytes, 119 inserts, 25 invalidations
0 load sharing elements, 0 bytes, 0 references
universal per-destination load sharing algorithm, id 3EDCA274
3(0) CEF resets, 1 revisions of existing leaves
Resolution Timer: Exponential (currently 1s, peak 1s)
1 in-place/0 aborted modifications
refcounts: 32828 leaf, 32768 node
Table epoch: 0 (94 entries at this epoch)
Adjacency Table has 90 adjacencies
81 IPv4 adjacencies
I have already followed the cisco doc which mentions the 'high cpu usage caused by interrupts'. These steps did not lead to decrease my cpu usage. Can anybody point me in a direction to troubleshoot the traffic that is causing this high cpu usage? Could this problem be CEF related?
Btw, IOS version 12.3(21)
Thanks in advance!
16 Replies 16
Danilo Dy
Can you post the output of "show proc cpu" or "show tech-support"?
Hi Medan,
Here is my 'show proc cpu' when downloading @ 15mbit:
NIDWORKR01#sh proc cpu | ex 0.0
CPU utilization for five seconds: 93%/81%; one minute: 24%; five minutes: 13%
3 20036 303 66125 10.95% 4.83% 2.44% 66 SSH Process
41 2480 1368 1812 0.55% 0.32% 0.22% 0 IP Input
I already tried upgrading to the latest 12.3(22) but no luck either. I think it's a bug somewhere but i am not sure at this. I hope someone can point me in a direction to let me show what interrupts are causing the cpu to go through the roof
I have included "show tech-support" in this one.
Your high CPU utilization is cause by SSH not .
PID CPU Time Process
3 28.69 SSH Process
Try the following and use telnet unless you are connecting from unsecured network (internet)
line vty 0 4
transport input telnet ssh
Improve TCP performance
service nagle
service tcp keepalive-in
service tcp keepalive-out
Hi medan,
SSH indeed caused some cpu spikes, but this was caused by my session to provide the output of "show tech-support". After that i started a downstream of 15mbit, and logged out of my SSH session. After a while i checked my cacti graph, and it was still peaking @ 75% cpu usage.
I will try to enable the services you mentioned above to improve tcp performance.
Thanks already!
When it happens again, use telnet (not SSH) to access and capture "show tech-support" before you reload the router (if you are going to reload it) and post it here.
Your IOS is okay, its the latest (GD) 🙂
Thanks medan,
I will use telnet the next time i will run "show tech-support". I will keep this topic updated about this issue. Thanks thus far
Hi again,
I enabled telnet access to the box and run tech-support while cpu was hogging again. See attached file.
Ok, this time with attachment 🙂
Yeesh, its high cpu util
1. Add the following
service nagle
2. Check this link http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml#pxf_punts
Just do the following below as I already checked the others from your "show tech-support" output and they are okay;
# An inappropriate switching path is configured on the router
# The CPU is performing alignment corrections
# Too many packets are being punted from PXF to the Route Processor (RP)
Your IOS is okay, the router interface is not overloaded with traffic.
Do you have "%ALIGN-3-CORRECT" messages in the logs? If you have, capture the output of the "show align" command
I have added those 3 services which gave me the following results:
CPU utilization for five seconds: 91%/76%; one minute: 43%; five minutes: 19%
123 10932 298 36684 13.91% 3.20% 0.96% 66 Virtual Exec
Alignment errors:
NIDWORKR01#sh align
No spurious memory references have been recorded.
I don't have any log lines about alignment or other possible misbehavior either 😕
I will check statement 1 and 3 tomorrow. Btw, something that could possibly be a reference point in solving this mystery:
Buffers:
NIDWORKR01#sh buffers
Buffer elements:
1118 in free list (1000 max allowed)
343951 hits, 0 misses, 1119 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50, peak 96 @ 1d03h):
48 in free list (20 min, 150 max allowed)
202772 hits, 42 misses, 46 trims, 46 created
1 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 49 @ 1d03h):
23 in free list (10 min, 150 max allowed)
29261 hits, 8 misses, 24 trims, 24 created
0 failures (0 no memory)
Big buffers, 1536 bytes (total 50, permanent 50, peak 92 @ 1d03h):
49 in free list (5 min, 150 max allowed)
29746 hits, 220 misses, 42 trims, 42 created
135 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 13 @ 1d03h):
10 in free list (0 min, 20 max allowed)
76 hits, 59 misses, 3 trims, 3 created
59 failures (0 no memory)
Large buffers, 5024 bytes (total 1, permanent 0, peak 3 @ 1d03h):
1 in free list (0 min, 10 max allowed)
8 hits, 51 misses, 12 trims, 13 created
51 failures (0 no memory)
Huge buffers, 18024 bytes (total 1, permanent 0, peak 2 @ 1d03h):
1 in free list (0 min, 4 max allowed)
4 hits, 47 misses, 11 trims, 12 created
47 failures (0 no memory)
You can some failures going on in a few buffer pools, i still have to check that out.
Thanks again
Regarding buffer counter, this is strange because the input/output queue of the interfaces looks normal plus the throttle and drops are zero.
I also checked your free memory, it looks good. Do you have this error in your log? %SYS-2-MALLOCFAIL
The buffer counter can only be cleared by reloading the router. If you can have maintenance downtime, try to reload the router to clear the buffer counter. Then we observe the buffer counter, because you might be looking at historical buffer that has nothing to do with the current problem.
Incorrect adjustment of system buffer can severely affect hardware and network performance, therefore we want to make sure that you really have buffer problem. I'm still looking for the buffer calculator, I can't find it 🙂
Here's useful link about buffer counters
http://www.cisco.com/en/US/products/hw/iad/ps397/products_tech_note09186a00800a7b85.shtml
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a7b80.shtml
If you have back-to-back maintenance with Cisco, I suggest you open a TAC case with them
I will schedule a reboot this night to clear buffer counters. Maybe one thing I forgot to mention is that the DSL connection is terminating in a thomson speedtouch adsl2+ modem which is set to bridged mode, so it kinda proxies all connection to this hop, the 2621. I already disabled all of the unneeded services in this modem, like ids, firewall etc. But maybe the communication between these two is not optimum. I'll keep you posted!
I finally had time to do a reboot, but i am still experiencing some high CPU usage caused by interrupts. Is this just the max a cisco 2600 router can do with NAT enabled?
Thanks..
