High CPU Usage on 3850
I have a stack of 5  WS-C3850-48P running IOS 16.3.6.
A newer IOS has not been authorized yet for my company so upgrading IOS is not an option.
I saw a bug in the older IOS 16.3.3 that the IOSD ipc task would max out the CPU.   I have multiple 3850's running 16.3.6 with no issue but in one case the IOSD ipc task is causing the CPU to run at a constant 70 to 90 percent.
I am monitoring this device's CPU with Prime Infrastructure 3.4 and below is a copy of the command "show process cpu | ex 0.0"
Any help would be much appreciated.
c3850-a01-zamjp-101-CMDCTR-0101-1s1#sho processes cpu | ex 0.00
CPU utilization for five seconds: 70%/27%; one minute: 77%; five minutes: 76%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
67 12234013 7303339 1675 0.39% 0.39% 0.39% 0 Net Background
74 1157800167 180749246 6405 39.95% 41.08% 41.07% 0 IOSD ipc task
91 2874211 6767303 424 0.07% 0.09% 0.08% 0 cpf_process_tpQ
111 1626020 29843562 54 0.07% 0.05% 0.05% 0 100ms check
118 1055734 5208071 202 0.07% 0.13% 0.07% 0 IOSXE-RP Punt Se
136 35330646 12607273 2802 1.42% 1.13% 1.14% 0 PLFM-MGR IPC pro
137 4545331 762258 5962 0.23% 0.15% 0.15% 0 FEP background p
138 1061137 304905 3480 0.07% 0.04% 0.02% 0 XPS background p
183 2569911 4473606 574 0.07% 0.07% 0.07% 0 Inline Power
190 3707017 41130020 90 0.15% 0.10% 0.09% 0 VRRS Main thread
196 12212408 7366089 1657 0.39% 0.38% 0.39% 0 CDP Protocol
204 2858665 55339339 51 0.08% 0.05% 0.07% 0 IPAM Manager
233 12771167 30322707 421 0.48% 0.39% 0.39% 0 UDLD
377 2400464 19488478 123 0.08% 0.09% 0.08% 0 PM Callback
507 10914107 13146518 830 0.24% 0.31% 0.33% 0 LLDP Protocol
520 443 164 2701 0.32% 0.36% 0.12% 2 SSH Process
2 Accepted Solutions
Thank you for sharing this update.
I was suspecting of a knwon issue seen when you have the following command in interface configuration without having a voice vlan configured:
authentication event server dead action authorize voice
The previous "misconfiguration" causes High CPU, but it has been seen on different platform running 16.6.x
Ok.   The current set up does not call for a voice network yet.  So it was not added.  Because I knew voice was going to be installed at a later date I went ahead and added it to the switch.  CPU instantly dropped down to 25% and continuing to hold.   Again I am on 16.3.6 with a stack of 4 3850's being used as a layer 3 device.
Thank you for the help.
10 Replies 10
show ipc hog-info
https://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/s_hogipc.html
If this posts answers your question or is helpful, please consider rating it and/or marking as answered.
andresfr
Can you please provide the output of the following commands?
show platform software fed switch active punt cause summary
show platform software fed switch active inject cause summary
show platform hardware fed switch active qos queue stats internal cpu policer
show processes cpu platform sorted
show proc cpu sorted | exc una
show memory debug leaks
sho platform software fed switch active punt cause summary
Statistics for all causes
Cause Cause Info Rcvd Dropped
7 ARP request or response 86060307 0
11 For-us data 6235673 0
21 RP<->QFP keepalive 1648636 0
24 Glean adjacency 333228 0
29 RP handled ICMP 95718 0
45 BFD control 21 0
55 For-us control 1961679 0
58 Layer2 bridge domain data packet 244265 0
60 IP subnet or broadcast packet 798750 0
74 ACL log 50453 0
96 Layer2 control protocols 676555 0
97 Pakcets to LFTS 81050 0
1 L2 control/legacy 71419555 0
2 QFP destination lookup 10044994 0
5 QFP <->RP keepalive 1648700 0
7 QFP adjacency-id lookup 1480683 0
12 ARP request or response 4173162 0
43 Applications Injecting Pkts usin 356651 0
QId PlcIdx Queue Name Enabled Rate Rate Drop
0 11 DOT1X Auth No 1000 1000 0
1 1 L2 Control No 500 500 0
2 14 Forus traffic No 1000 1000 0
3 0 ICMP GEN Yes 200 200 0
4 2 Routing Control Yes 1800 1800 0
5 14 Forus Address resolution No 1000 1000 0
6 3 Punt Copy to ICMP Redirect No 500 500 0
7 6 WLESS PRI-5 No 1000 1000 0
8 4 WLESS PRI-1 No 1000 1000 0
9 5 WLESS PRI-2 No 1000 1000 0
10 6 WLESS PRI-3 No 1000 1000 0
11 6 WLESS PRI-4 No 1000 1000 0
12 0 BROADCAST Yes 200 200 0
13 10 Learning cache ovfl Yes 100 100 0
14 13 Sw forwarding Yes 1000 1000 0
15 8 Topology Control No 13000 13000 0
16 12 Proto Snooping No 500 500 0
17 16 DHCP Snooping No 1000 1000 0
18 9 Transit Traffic Yes 500 500 0
19 10 RPF Failed Yes 100 100 0
20 15 MCAST END STATION Yes 2000 2000 0
21 13 LOGGING Yes 1000 1000 0
22 7 Punt Webauth No 1000 1000 0
23 10 Crypto Control Yes 100 100 0
24 10 Exception Yes 100 100 0
25 3 General Punt No 500 500 0
26 10 NFL SAMPLED DATA Yes 100 100 0
27 2 Low Latency Yes 1800 1800 0
28 10 EGR Exception Yes 100 100 423424
29 16 Nif Mgr No 1000 1000 0
30 9 MCAST Data Yes 500 500 0
31 10 Gold Pkt Yes 100 100 0
CPU utilization for five seconds: 85%, one minute: 85%, five minutes: 85%
Core 0: CPU utilization for five seconds: 84%, one minute: 83%, five minutes: 84%
Core 1: CPU utilization for five seconds: 88%, one minute: 85%, five minutes: 86%
Core 2: CPU utilization for five seconds: 86%, one minute: 85%, five minutes: 86%
Core 3: CPU utilization for five seconds: 86%, one minute: 86%, five minutes: 85%
   Pid    PPid    5Sec    1Min    5Min  Status        Size  Name
 11470   10478     69%     71%     73%  R       2021191680  linux_iosd-imag
 13508   12439     55%     54%     53%  R        636878848  smd
 10395    9510     51%     50%     49%  R        559919104  fman_rp
 16844   14617     31%     30%     30%  S       1395531776  sif_mgr
 16378   14115     22%     22%     23%  S       2472513536  fed main event
 32746   31253     17%     17%     17%  S        302845952  repm
 28777   26333      3%      3%      3%  S        648773632  fman_fp_image
 10850    9563      1%      1%      1%  R        508071936  hman
    21       2      1%      1%      1%  S                0  rcuc/3
    16       2      1%      1%      1%  S                0  rcuc/2
 32744   32006      0%      0%      0%  S          4268032  bexec.sh
 32273   31033      0%      0%      0%  S        502558720  plogd
 32006   31970      0%      0%      0%  S          5914624  brelay.sh
 31970   31174      0%      0%      0%  S         11988992  in.telnetd
 31969       1      0%      0%      0%  S         13627392  rotee
CPU utilization for five seconds: 68%/26%; one minute: 68%; five minutes: 69%
  74  1252680005   201873207       6205 37.03% 35.58% 36.32%   0 IOSD ipc task
 136    38552894    13802235       2793  1.75%  1.22%  1.17%   0 PLFM-MGR IPC pro
 515     2304009     4509346        510  0.63%  0.07%  0.06%   0 OSPF-78 Router
  67    13389246     8259489       1621  0.47%  0.40%  0.40%   0 Net Background
 507    11904606    14368028        828  0.47%  0.35%  0.35%   0 LLDP Protocol
 233    13940851    33098957        421  0.39%  0.41%  0.41%   0 UDLD
 196    13327456     8038351       1657  0.39%  0.39%  0.39%   0 CDP Protocol
  35    33331041    28267894       1179  0.31%  1.55%  1.12%   0 ARP Input
  91     3144807     7429974        423  0.15%  0.09%  0.08%   0 cpf_process_tpQ
 377     2624577    21287959        123  0.15%  0.09%  0.08%   0 PM Callback
 137     4959664      831790       5962  0.15%  0.13%  0.14%   0 FEP background p
 520         904        1277        707  0.15%  0.05%  0.05%   2 SSH Process
 118     1247143     6415582        194  0.07%  0.03%  0.05%   0 IOSXE-RP Punt Se
 190     4074112    45135507         90  0.07%  0.11%  0.10%   0 VRRS Main thread
 236      176379      288076        612  0.07%  0.00%  0.00%   0 CEF background p
 207     2965601    61394092         48  0.07%  0.08%  0.07%   0 IP ARP Retry Age
I ran this command and it wouldn't display anything.
Thanks for the help.
yaplej
I am having the same exact problem on a few of my 3850 stacks running 16.6.3.  All of them are setup a provisioned exactly the same.
CPU utilization for five seconds: 62%, one minute: 69%, five minutes: 68%
Core 0: CPU utilization for five seconds: 53%, one minute: 70%, five minutes: 70%
Core 1: CPU utilization for five seconds: 52%, one minute: 69%, five minutes: 67%
Core 2: CPU utilization for five seconds: 57%, one minute: 69%, five minutes: 68%
Core 3: CPU utilization for five seconds: 55%, one minute: 68%, five minutes: 68%
4559 3923 100% 99% 100% R 2131861504 linux_iosd-imag
3838 2817 41% 55% 57% S 745037824 fman_rp
32294 30366 37% 49% 50% R 804732928 smd
20722 19415 13% 16% 17% S 1611341824 sif_mgr
19196 17292 11% 10% 10% S 2624487424 fed main event
31002 29282 7% 10% 10% S 843722752 fman_fp_image
30822 28916 5% 5% 5% S 755179520 repm
show proc cpu sort | ex 0.00
CPU utilization for five seconds: 92%/36%; one minute: 92%; five minutes: 92%
74 4654743 816164 5703 55.16% 53.49% 52.62% 0 IOSD ipc task
206 62037 56743 1093 0.64% 0.72% 0.72% 0 Spanning Tree
132 35399 18016 1964 0.64% 0.41% 0.39% 0 PLFM-MGR IPC pro
I found this to be odd.
sh platform software infrastructure thread scheduler
Statistics for IOS scheduler activities:
 0 msec minimum clock runtime, 4335 msec maximum clock runtime
 0 msec minimum cpu runtime, 3698 msec maximum cpu runtime
 0 msec minimum sleep time, 27 msec maximum sleep time,  578255 interrupted
 6835531 IOS Scheduler invocation, 3529093 idle
 0 sec wallclock, (4464448471132%) IOS tasks, (13393345526371%) scheduler, (13393345548240%) sleep
Perhaps related to this?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus28046
Sorry for my delayed response,
Are you having dot1x configured on this switch?
Can you please run this command 3 times and provide the outputs?
show platform software fed switch active cpu-interface
I noticed that we are having some EGR exception drops at the control plane:
...omitted output...
So, some egress traffic is not being processed as expected and is being sent to CPU to take care of it.
Yes we are using 802.1x.
Please see the output from sho platform software fed switch active cpu-interface.
c3850-a01-zamjp-101-CMDCTR-0101-1s1#sho platform software fed switch active cpu-interface
queue                      retrieved   dropped     invalid     hol-block
Routing Protocol           310452      0           0           0
L2 Protocol                107244      0           0           0
sw forwarding              62523       0           0           0
broadcast                  124876      0           0           0
icmp                       0           0           0           0
icmp redirect              0           0           0           0
logging                    10221       0           0           0
rpf-fail                   0           0           0           0
DOT1X authentication       37992       0           0           0
Forus Traffic              2069488     0           0           0
Forus Resolution           12886731    0           0           0
Wireless q5                0           0           0           0
Wireless q1                0           0           0           0
Wireless q2                0           0           0           0
Wireless q3                0           0           0           0
Wireless q4                0           0           0           0
Learning cache             0           0           0           0
Topology control           0           0           0           0
Proto snooping             1489        0           0           0
BFD Low latency            0           0           0           0
Transit Traffic            0           0           0           0
Multi End station          37561       0           0           0
Health Check               0           0           0           0
Crypto control             0           0           0           0
Exception                  0           0           0           0
General Punt               0           0           0           0
NFL sampled data           0           0           0           0
STG cache                  0           0           0           0
EGR exception              25224       0           0           0
FSS                        0           0           0           0
Multicast data             0           0           0           0
Routing Protocol           310473      0           0           0
L2 Protocol                107246      0           0           0
broadcast                  124885      0           0           0
icmp                       0           0           0           0
logging                    10221       0           0           0
rpf-fail                   0           0           0           0
Forus Traffic              2069592     0           0           0
Forus Resolution           12886757    0           0           0
Wireless q5                0           0           0           0
Wireless q1                0           0           0           0
Wireless q2                0           0           0           0
Wireless q3                0           0           0           0
Wireless q4                0           0           0           0
Multi End station          37564       0           0           0
Exception                  0           0           0           0
STG cache                  0           0           0           0
FSS                        0           0           0           0
Routing Protocol           310484      0           0           0
L2 Protocol                107248      0           0           0
broadcast                  124891      0           0           0
icmp                       0           0           0           0
logging                    10221       0           0           0
rpf-fail                   0           0           0           0
DOT1X authentication       37999       0           0           0
Forus Traffic              2069615     0           0           0
Forus Resolution           12886775    0           0           0
Wireless q5                0           0           0           0
Wireless q1                0           0           0           0
Wireless q2                0           0           0           0
Wireless q3                0           0           0           0
Wireless q4                0           0           0           0
Exception                  0           0           0           0
STG cache                  0           0           0           0
FSS                        0           0           0           0
I upgraded to 16.6.4 and the high CPU issue went away.
show proc cpu sorted | ex 0.00
CPU utilization for five seconds: 11%/3%; one minute: 50%; five minutes: 41%
 468        1273       21408         59  1.43%  0.88%  0.31%   0 IP SLAs Responde
 467        1266       21468         58  1.27%  0.89%  0.32%   0 IP SLAs Control
 465         527         674        781  0.87%  0.18%  0.11%   0 LLDP Protocol
 132         414         498        831  0.63%  0.15%  0.08%   0 PLFM-MGR IPC pro
 206        1219        1507        808  0.39%  0.48%  0.29%   0 Spanning Tree
 340        1308         324       4037  0.31%  0.07%  0.19%   5 SSH Process
 114         566        3986        141  0.31%  0.18%  0.12%   0 IOSXE-RP Punt Se
 144         343         344        997  0.31%  0.05%  0.02%   0 Inline Power
  67         628         579       1084  0.23%  0.15%  0.10%   0 Net Background
  79         686          49      14000  0.23%  0.14%  0.09%   0 Crimson flush tr
 324         162        6473         25  0.15%  0.07%  0.03%   0 MMON MENG
  91          76         275        276  0.15%  0.07%  0.01%   0 cpf_process_tpQ
 292         210        3372         62  0.15%  0.09%  0.04%   0 MMA DB TIMER
  74       15566        5149       3023  0.15%  1.74%  2.46%   0 IOSD ipc task
 207         281        2390        117  0.15%  0.13%  0.07%   0 UDLD
 323         187        3373         55  0.07%  0.06%  0.03%   0 MMA DP TIMER
 195         177        5326         33  0.07%  0.08%  0.04%   0 IP ARP Retry Age
 181         195        3374         57  0.07%  0.07%  0.04%   0 VRRS Main thread
 133         176          69       2550  0.07%  0.06%  0.04%   0 FEP background p
 377         499        1804        276  0.07%  0.07%  0.08%   0 SISF Main Thread
Unfortunately I am not able to upgrade to 16.6.X.    We are limited to 16.3.X and the latest 16.3.6 is what we are using.  This is only happening on this one device, however this is the only device that is running layer 3.
Thoughts?
