High CPU utilization
I am facing a prolem my cpu utilization goes high intermittenly
my router has ios : c2600-ipbase-mz.123-26.bin
Model: cisco 2621XM
plz find the" show pro cpu" its show 99% , also plz ignore the virtual exec process as this i have used to generate the show tech outout.
I have to removed the show run due to security issue.
I m using multilink can that be a reason and also load i doubt in the link load also, can someone plz comment on muy onbservation.
Thaks in advance
Laurent Aubert
So from what you said the CPU spikes are correlated to an unknown recurrent event right ? Do you have SNMP polling in place ? Any instability with your routing protocol ? Any script running an a regular basis which could poll the router as well ?
Do you have cef enabled ?
Laurent.
Yes cef has been enabled and  i can see high cpu utilization in the " show proc cpu" but not able to trace the exact process that is causing high cpu.
I have seen in the cisco output inter[retter and it show load is due to interrupt and is caused by high traffic but i want to analyze which IP s are generating high traffic what steps or command output will help me in analyzing the same.
In the " show interface switching" shows:
show interfaces switching
FastEthernet0/0
          Throttle count          0
                   Drops         RP          0         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs      41528      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process      53922    5326429      83037   36967369
            Cache misses      65673          -          -          -
                    Fast  102813512 2249272985   95996295 1668803525
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0        266      20482
            Cache misses          0          -          -          -
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
Process      41522    2491320        291      17460
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process       5292     296352      15829     949740
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    NOTE: all counts are cumulative and reset only after a reload.
FastEthernet0/1
         Throttle count          0
                   Drops         RP          0         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs       1070      Drops          0
    Protocol  IP
--More--                     Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process     143652   85012905     101498   53325996
            Cache misses        906          -          -          -
                    Fast   95700365 1869229308  102494868 1962945539
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process         14        840         38       2280
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0      15829     949740
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Thnaks
Here are some links that will help you into the troubleshooting process:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af3.shtml
In addition to that, you can try capturing packets which are punted to the CPU with the sh buffer input-interface header | packet. You need to run this command several times during the high CPU issue as you will not capture a packet each time.
Also you could activate netflow which will give you a list of all the flow going through the router. It may help you identify unexpected traffic. Finally show ip traffic will give you detailed statistics.
Laurent.
