High CPU
Robo123
Hi Guys,
I am observing High cpu on my N7k M1 ( N7K-M132XP-12L) line card due to "aclqos" process which is consuming 78% of cpu.
CPU utilization for five seconds: 100%/2%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
2241 170313450 45702780 3 86.39% 81.75% 80.16% - aclqos
Can any one help to know what is this process indicates and how to troubleshoot the same.
9 Replies 9
balaji.bandi
what is the version of nexus code running, look some bug reported  here :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg37701/?rfs=iqvred
here are the steps for troubleshooting high CPU
https://www.cisco.com/c/en/us/support/docs/interfaces-modules/nexus-7000-series-supervisor-1-module/116137-trouble-nexus7000-highcpu-00.html
BB
Hi Balaji ,
Thanks for sharing the document.
As i have already gone through this.
With respect to the bug the CPU utilization of line card almost 100%  ,the  cpu is taking around 1 hour recovered are matching with the scenario but the Symptom 1 is not matching  (Console get stuck after performed default interface command.).I didn't performed any default int config ,also verified "show system internal ethpm errors" , "show interface status error policy detail" but nothing able to find for interface related issue.
Run ver:-6.2(22).
Reg document i tried to dig deep the process id which was causing the issue but can see "aclqos service never crashed since the last reboot."
Could you please suggest here.
can you post the output of:
show processes memory | include aclqos
Hi Georg,
Please find the below
#show processes memory | include aclqos
2541 169373696 0 272687104 7fa3da60/7fa3c740 aclqos
thank you for the input.
So after reboot, do you still see high CPU process ? how long was the device uptime before you reload or reseat the module ?
BB
Hi Balaji,
The device rebooted 80 days back but still i can see high CPU in one of the M1 LC
show you post output
show process cpu |  ex 0.00
show process cpu history.
show loggin last 50
BB
#sh processes cpu sor | ex 0.0
CPU utilization for five seconds: 100%/0%; one minute: 99%; five minutes: 99%
2211 189207150 23249211 8 21.73% 3.39% 2.85% - sensor
# sh processes cpu his
111111111111111111111111111111111111111111111111111111111111111111111111
000000000000000000000000000000000000000000000000000000000000000000000000
100 **#***********************#***********************#*********************
90 **#***********************#***********************#*********************
80 **#***********************#***********************#*********************
70 **#***********************#***********************#*********************
60 **#***********************#***********************#*********************
50 *##**********************##**********************##*********************
40 *###*********************###*********************###********************
30 *###*********#***********###***#*****************###******#********#***#
20 ########################################################################
10 ########################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
as of now, i do not see any solution, if you have a cisco contract raise a TAC case to investigate for you.
another option upgrade to a new code of nexus os.
BB
