Hikvision NVR (DS-96XX) and WS-C2960+48TC-L
Jelani_DTE_PRO
Hello.
So, I have this little issue... Whenever, a recently purchased Hikvision NVR LAN port is configured with IP settings specific to a VLAN created on my WS-C2960+48TC-L switch and connected to a switchport that is configured as an access port for access to that VLAN, the NVR is able to successfully reply to ICMP request. Then, after several minutes, you can no longer communicate with it.
I believe, and I feel bad for not grabbing that information before now, but I believe the Hikvision NVR model is a DS-96XX.
Any ideas, as to what might cause the NVR to longer communicate? Oh! And, I've moved it to a different switchport; same results. Thanks!
6 Replies 6
where are you pinging from, that is, which device is doing the (inter) Vlan routing ? Is the port actually going down when you lose connectivity ?
One thing you could try is to configure the MAC address of the device as a sticky MAC, e.g.:
switchport port-security mac-address 0050.3e8d.6400 (<-- MAC address of the Hikvision)
Hi, Georg.
I've actually had to disable port security and MAC sticky, on the switchport. Whenever it's enabled, the Hikvision connection causes an immediate port security violation...causing the port to shutdown. I was pinging, from the switch that the Hikvision connects to. I was able to successfully ping the IP address of the NVR from the switch and the vendor was able to ping it, from the command line of his laptop. Then, after about 5 minutes, we were no longer able to communicate with it...from both the switch or his laptop.
The port doesn't go down...the NVR just doesn't respond to ICMP request, after a short while.
Hello
Is this access-port in an administrative mode of access?
Do you have any port-security or storm control set on the access-port?
sh interface xx switchport
sh spanning-tree interface xxx
sh port-security interface xxx
sh mac address interface xx
sh log
Kind Regards
Paul
Hi, Paul.
Hmmm... Will you give me an example, of an administrative mode type of config on a switchport? Here's how the port, has been configured... Again, I was able to successfully ping the NVR for about 5 minutes from the switch. And, the vendor was able to ping the NVR from the command line of his laptop, during that window of time. After the 5 minutes, we were unable to successfully ping the NVR.
Hello
The administrative mode of a port is set with the - switchport mode xx command as such that port is in an administrative mode of access.
It is interesting to see that you did have port-security initially enabled, so when you removed it did you shutdown/renable to the port that had mac-address sticky applied to this device?
int x/x
no switchport port-security mac-address sticky
shut
no shut
exit
show interface status err-disabled
Kind Regards
Paul
Hi, Paul.
Gotcha! In the case of administrative mode, using switchport mode xx, I did. Thanks, for the explanation; haven't heard it like that, in a while. As for port security, it was removed before communication was tested and prior to port security becoming a problem. After, which, the NVR communicated for a solid 5 minutes. Then, fell off.
