Nexus 9k switch remote access
war202994
Visitor
HI I have a pair of 9k switches running both layer 3 and 2, we are low on ports so I am trying to introduce another
9k switch but only as a pure layer 2 switch.  I have an existing vlan that I will us trunk/port chnnels to connect the
new switch to the existing 2.  I also configured a loopback address as well, I can see the trunk ports, port channel
and ethernet ports are up.  I can ping both the vlan and loopback on the new switch.  I can also see that it is learning
mac addresses from the existing switch but the issue is I cannot get to it remotely. I see we cannot put in a default gateway
or at least didn't find the command.  What am I doing wrong? Is there a document that I can follow to show me this?
Thank you in advance!!!
ok so issue resolved so here is what happened, ended up creating a separate management vlan, I was trying to use the existing one
New Switch layer2        Existing Switch layer2/3
vlan 2020        vlan 2020
ip address 172.20.10.36/28        ip address 172.20.10.35/28
                                                   Trunk port
10.10.10.1    -Eth1/45--------------------------------Eth1/45-----     10.10..10.2
ip route 0.0.0.0/0 172.20.10.35        router bgp 65466
        address-family ipv4 unicast
        network 172.20.10.32/28
once all this was done I was able to get to the switch remotely
6 Replies 6
balaji.bandi
You need to add default route
ip route 0.0.0.0/0 x.x.x.x
if you using mgmt0 interfaces, which are configured under VRF 'management' you will need to configure the following
vrf context management
BB
I am no using the mgmt0 interface just using a vlan, I already have a default route
ip route 0.0.0.0/0 10.10.10.2
and to get to the loopback address on the layer 3 switch that this is attached to
I have a static routing pointing back to the interface
ip route 172.20.8.5/32 10.10.10.1
but I still cannot get to the switch remotely   I notice when I do a sh ip route it says
IP Route Table for VRF "default"
do I need to do anything to the vlan??
Thank you sir
the fastest way to resolve this is for you to post the full running configurations of both switches. Whatever IP address you have configured on the layer 2 switch, it needs to have a corresponding IP address in the same subnet on the layer 3 switch.
HI George
I can't post it publicly due to company policy is it ok if I can send to you directly?
Not sure if this helps but the connection goes like this
New switch added as pure layer 2                                                           Existing switch using both Layer 2 and 3
LAYER 2 using default VRF        Layer 3 using default VRF
vlan 2018                                       trunk port                                            vlan2018
10.10.10.1    -Eth1/45-----------------------------Eth1/45-----     10.10..10.2
loopback1
172.20.8.5
ip route 0.0.0.0/0 10.10.10.2        ip route 172.20.8.5/32 10.10.10.1
vlan 2020        vlan 2020
                                                   Trunk port
