Home network
THussain
Frequent Visitor
Frequent Visitor
Hi all, I'm trying to experiment with a Layer 3 switch (Cisco 4948-10GE). My aim is to set this switch as part of my home network.
I'm trying to get routing working on it but seem to be hitting a wall somewhere. I've searched alot a round and cannot see what I am missing.
My basic setup is a BT Home infinity (FTTH) hub (192.168.1.254) connected directly to my L3 switch port G1/1, Config for this is
inteface GigabitEthernet1/1
description BT ADSL 300Mb
no switchport
ip address 192.168.1.10 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.1.254
Gateway of last resort is 192.168.1.254
I also have 2 test VLANS 10 and 20. Config for these are:
inteface vlan10
ip address 10.10.10.1 255.255.255.0
interface vlan20
ip address 20.20.20.1 255.255.255.0
Now if I have a port Gi1/10  in vlan 10  and connect a PC to it, I cannot access the Internet. although the default route is set as mentioned above.
The PC picks up a 192.168.1.x address from the DHCP on the BT Infinity Hub. So could this be the problem? i.e. a 192.168.1.x device in VLAN 10 ?
I can ping the gateway from the switch but not from the PC.
I've not tried pinging a device from vlan 10 to vlan 20 as yet. I just wanted to sort out the Internet access first.
Any advice guys?
andresfr
Hello Hussain,
It's my understanding that you have the following scenario and configuration:
  |BT Home    |    Gi1/1|Cat4948    |
  |Infinity Hub+----------+            |
  |192.168.1.254          |            |
                                |G1/10
                                |Vlan 10
                          |  PC      |
                          192.168.1.X
no switchport
interface vlan10
Based on what you have described, I would suggest trying a different approach regarding the configuration of the Catalyst 4948 switch.
One quick question, are you able to ping a destination on the Internet from the switch?
Try ping 8.8.8.8
* Please keep in mind that even if you manually configure the PC manually to have an IP address in subnet 10.10.10.0/24, you'll need to ensure that the BT Hub performs the network address translation (NAT) so that the traffic from the PC can be routable on the Global Internet by translating its private IP address to a public IP address.
* Please consider defaulting the configuration of interface Gi1/1 connecting to the BT HUB:
configure terminal
default interface Gi1/1
end
* You can create a new SVI or use VLAN 10 SVI but with an IP address in the 192.168.1.0/14 network.
configure terminal
interface vlan10
no shut
end
* Then you could assign both interfaces Gi1/1 and Gi1/10 to VLAN 10
configure terminal
interface Gi1/1
  switchport
  switchport mode access
  switchport access vlan 10
  spanning-tree portfast
  no shut
  exit
interface Gi1/10
  switchport
  no shut
  end
* Make sure that IP routing is enabled on the switch and also that you still have the default route pointing to the BT HUB.
configure terminal
ip routing
end
* After this, the PC should still receive an IP address in the 192.168.1.0/24 network and should be able (if the proper NAT rules are in place) to surf the Internet. You should also be able to ping the BT home hub and a destination on the Internet, like 8.8.8.8, from the PC.
Please let me know if this configuration solves your issue.
Kelli Glass
Administrator
Administrator
Tawqeer,
I am moving your post to the Switching community space for better visibility and access to feedback.
Switching
Kelli Glass
Moderator for Cisco Customer Communities
andresfr
Hello Hussain,
  |192.168.1.254          |            |
                                |G1/10
                                |Vlan 10
                          |  PC      |
                          192.168.1.X
no switchport
interface vlan10
Try ping 8.8.8.8
configure terminal
end
configure terminal
interface vlan10
no shut
end
configure terminal
interface Gi1/1
  switchport
  no shut
  exit
interface Gi1/10
  switchport
  no shut
  end
configure terminal
ip routing
end
If you want the switch to route, then the question is whether the BT Hub knows about the 10.x.x.x network. My guess is that it does not. Do you have the ability to configure that device or is it managed by your ISP? If you can configure it then you need to add a route to it that points the 10.x.x.x subnet to the 192.168.1.10 address. If the ISP manages it then you will not be able to do routing unless the switch is capable of NAT. which I don't believe it is. All this trouble is because your ISP is expecting data only from the 192.168.1.x subnet.
I hope this is helpful.
Hi Andres, First of all apologies for a late response.
To answer your question, yes I could ping 8.8.8.8 from the switch but obviously not from the PC.
I have configured as you mentioned and it all works great. I can access the internet fine now.
My next step is to be able to do inter-vlan routing between VLAN 10 and VLAN 20 for example.
I know I'll need to setup a router for this as the 4948 switch for some reason will not do NATing although the commands are there.
Will have a look at this next time.
Thanks for your help.
