Hot-plug port adaptor for 7301 router?
hoffa2000
Level 3
Level 3
We have and empty slot and a GBIC port adaptor card with an ZX GBIC installed. Can this be installed into the router online or do I have to power it off?
Fredrik Hofgren
spremkumar
Level 9
Level 9
Hi Frederik
You can install the GBIC Module onto the slot and start configuring it as per your requirement...
regds
Thank you for your response. But is it also possible to install and use the entire port adaptor online?
