How can i enable Jumbo frame with EHWIC-4ESG?
danielchau
Dear all
According to the documentation, it should be supported,
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/qa_c67-612908.html
However, i cannot found out any documentation, or any cases on the internet, that can enable this .
I have got a cisco 1921 router but failed with common way to enable the mtu
1921#sh int gigabitEthernet 0/1/0
GigabitEthernet0/1/0 is up, line protocol is up
Hardware is EHWIC-4 Gigabit Ethernet, address is b0fa.ebd3.9ce8 (bia b0fa.ebd3.9ce8)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
1921(config)#int gigabitEthernet 0/1/0
1921(config-if)#system mtu?
% Unrecognized command
1921(config-if)#mtu?
Would you please kindly help on this?
Thanks.
Daniel
mile.ljepojevic
System MTU is on global configuration mode, not on interface, so try it there...
On Interface, try IP MTU ...
Thanks.
Thanks Mile,  tried seems also not work...
r1921(config)#int gigabitEthernet 0/1/0
r1921(config-if)#ip mtu?
n-kirillov
Hi Daniel!
It's changed in vlan configuration mode
Enter configuration commands, one per line. End with CNTL/Z.
RIGHT_2911(config)#vlan 511
RIGHT_2911(config-vlan)#mtu ?
<1500-18190> Value of VLAN Maximum Tranmission Unit
Good luck
CCIE, Irkutsk, Russia
Sincerely from Nik
