How disable system message of Cisco Routers.
Hi Guys I´m new here, and I´m studying of CCNA in the Dominican Republic.
How can I disable systema message or alerts of a router or switch???
Example:
if i type: no shutdown in a interface display the following message or alert
%LINK-5-CHANGED: Interface FastEthernet0/1, changed state to upEste(config-if)#
or if after that I type end, the following message or alert appear:
%SYS-5-CONFIG_I: Configured from console by console
How can I disable this??? Help me!
Thank!
2 Accepted Solutions
use this command in the global config mode
"no logging console"
Ganesh Hariharan
Example:
Thank!
This command is quite straight forward and you’ll loose the ability to see what’s going on in the router/switch  while you are configuring. You might want to know when a network interface goes up or down, neighbor relationship formation, etc. So this is the least useful method, but you do not get any messages on your console.
no logging console
Check out the below link for more info:-
http://www.cisco.com/en/US/docs/ios/12_3/configfun/command/reference/cfr_1g04.html#wp1031439
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
9 Replies 9
When I am in switch configuration mode and typing the wrong command my console hung and when I am trying to use Ctrl +z it still taking more than 20 min time, could you please suggest me a command through which I will not get the error message and my console will not hang, as its getting hung and I am helpless at that time I am deleting the switch again and reinstall the configurations in Packet Tracer. Please see the attached screenshot for reference,
no ip domain-lookup should end that issue.
Thank you Dhannanjoy Chowdhury!
Ganesh Hariharan
Example:
Thank!
no logging console
Hope to Help !!
Ganesh.H
Hi Guys, thank for your answer that was what I was looking for.
Ganessh.iyer, I appreciated your recomendation but I´m not working in a real network, this is a practice that my teacher assigned me, is only a requeriment to complete the practice, in a real configuration I will try to no use.
Thank!
Jamesseibert11
Sorry to bump this ancient post, but it comes up at the top of google and I thought it was worth mentioning that maybe the original requester would have been happy with logging synchronous.
line con 0
 logging synchronous
luiztonello
for this problems command "no macro auto global processing".
just practice this command in global configuration mode
router(config)#no logging console
best regards,
Abdulrahman
AL-ATHWARI
