How do a create an ALLOW mac address list for switches?
sandsfoot
Hello
We would like to control who can connect to our network.
How do I create a list of ALLOWED mac addresses that are able to connect to our 9300 switches?
Kind Regards
Tony
here is an example:
9300(config)# mac access-list extended MAC_ACL
9300(config-ext-macl)#permit host 0ef3.2765.0342 any
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-5/configuration_guide/sec/b_165_sec_9300_cg/configuring_ipv4_acls.html#ID1832
balaji.bandi
There are 2 ways you can do, Sticky MAC address, that means  only that MAC address can connect to certain switch ports ?
or you looking to connect any MAC known address to limit to switch ?
some guide lines :
MAC ACLs on a Layer 2 Interface
After you create a MAC ACL, you can apply it to a Layer 2 interface to filter non-IP traffic coming in that interface. When you apply the MAC ACL, consider these guidelines:
  • You can apply no more than one IP access list and one MAC access list to the same Layer 2 interface. The IP access list filters only IP packets, and the MAC access list filters non-IP packets.
  • A Layer 2 interface can have only one MAC access list. If you apply a MAC access list to a Layer 2 interface that has a MAC ACL configured, the new ACL replaces the previously configured one.
Note
The mac access-group interface configuration command is only valid when applied to a physical Layer 2 interface. You cannot use the command on EtherChannel port channels.
BB
Hello
MACLs are very specific and can be an administrative burden, Can you elaborate on what you mean by controlling access, is this physically to a specific switch(s) or is it network?
If you want to enable port authentication, then it can be centralized using 802.1x port authentication (inc- Mac Auth bypass- MAB) which would be a more dynamic approach to specific MACLs
Kind Regards
Paul
sandsfoot
We have a secure environment so would like only known thin clients or laptops to be able to connect to the network - so looking for the simplest way to implement / administer?
