07-22-2022 06:05 PM
Beginner question here. I have a switch that was preconfigured. Do I need to connect it to my router in order to get it on my Wi-Fi? I have other devices that will connect to the switch. I hope my question makes sense.
Solved! Go to Solution.
07-22-2022 09:11 PM
you need to connect your switch to router which have internet. if your router have built-in wifi feature, you can use that. or you need wifi access point connected to network to access via wifi. very basic connectivity as below.
ISP internet router ------------ Switch ------------ wifi access point
WIfi devices cable connected wifi devices
devices
07-22-2022 09:11 PM
devices
