how do I set my cisco catalyst 3560 to use a static ip instead of an ip from our DHCP server?
dsymes001
How do I set my cisco catalyst 3560 to use a static ip instead of an ip from our DHCP server?    I want to monitor it with nagios and would like it to use an ip from our static range.
devils_advocate
Level 7
Level 7
#interface vlan [x]
#ip address 10.10.10.1 255.255.255.0
Replace the [x] with the VLAN ID of your manangement Vlan and the IP address and Mask for the ones you want to use.
18 Replies 18
Jon Marshall
Do you mean that currently the 3560 uses DHCP to get an IP address for it's management interface ?
If so can you post the output of -
a) sh boot
b) sh ip int br | include Vlan
Jon
As you can see I tried to set the vlan1 to a static IP thinking that would make the switch itself be pingable to check that it is running via that IP which is 192.168.1.13
SW3#sh boot
BOOT path-list      : flash:c3560-ipbasek9-mz.122-50.SE3.bin
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
Timeout for Config
          Download:    0 seconds
Config Download
       via DHCP:       disabled (next boot: disabled)
SW3#sh ip int br | include Vlan
Vlan1                  192.168.1.13    YES NVRAM  up                    up
Vlan2                  10.99.99.99     YES DHCP   up                    up
Why do you have two vlan interfaces (SVIs) on this switch ?
I assume if previously you were using DHCP for both interfaces then this switch could only be acting as L2 and not L3 ie. it is not doing any routing between vlans because the clients wouldn't know the correct default gateway ?
So are you saying you can't ping the switch ?
If so -
a) what IP address are you pinging from ?
b) which switch/router does handles the routing between vlans ?
Jon
Vlan1 is our local LAN (192.168.1.0/24) and lvan2 is our VOIP (call center IP phones) which are connected to an Adtran router on the 10.99.... subnet.
I'm trying to ping from our local LAN  from my ip: 192.168.1.101
Here is the route info from the config on SW3 (the switch we are discussing)
ip classless
ip route 0.0.0.0 0.0.0.0 172.23.181.1 254
ip route 0.0.0.0 0.0.0.0 192.168.1.14 254
ip http server
ip http secure-server
Here is the config from the switch connected to the adtran "VOIP" router:
Using 7821 out of 524288 bytes
version 12.2
no service pad
service password-encryption
hostname SW4
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
vtp domain fub
vtp mode transparent
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2
 name VOICE
interface FastEthernet0/1
 description PC/PHONE
 switchport mode access
 switchport voice vlan 2
 spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/47
interface FastEthernet0/48
 description PC/PHONE (uplink from Adtran 916e Router)
 switchport mode trunk
interface GigabitEthernet0/1
 description UPLINK-TO-SW3
interface GigabitEthernet0/2
 description UPLINK
interface GigabitEthernet0/3
 description UPLINK
interface GigabitEthernet0/4
 description UPLINK
interface Vlan1
 description DATA-VLAN
 ip address dhcp
interface Vlan2
 description VoIP-VLAN
 ip address dhcp
ip classless
ip http server
control-plane
end
Here is route info from another Cisco Catalyst 3560 (24-port) from the stack
interface Vlan1
 ip address 172.16.2.2 255.255.0.0
This is really confusing ie. -
interface Vlan1
 ip address 172.99.99.2 255.255.0.0
the subnet used in the above is totally different from the one you applied to SW3 for the same vlan.
Can you explain that ?
I think we need to understand your network layout and the IP addressing before we can say what you should do.
Jon
I agree with Jon that this is quite confusing. When the switch is operating as a layer 2 switch it really should have only a single interface vlan x to provide layer 3 functionality. On many layer 2 switch I have had the experience that when you configure a second SVI that the first one configured goes to protocol down. But other switches allow multiple SVIs and keep them in the up state. I have also seen situations where having multiple active SVIs on a layer 2 switch caused unexpected behaviors.
And I am quite puzzled at this part of the configuration
ip route 0.0.0.0 0.0.0.0 172.99.99.99 254
As a layer 2 switch I would not expect to see any ip route statements much less attempts to configure 4 default routes (but which duplicate the next hop on two route statements).
Rick
Rick
192.168.1.14 is our firewall
The other route is old, from previous VOIP provider.
I don't understand why the route info is there twice.
In terms of which switch is routing for the data vlan then what is the default gateway set to on the clients in that vlan ?
That IP address will be on one of your switches and hopefully on that switch there should also be a default route (or more than one :-)), pointing to the firewall.
It is a bit confusing how it has been setup.
It sounds like you can ping the switch now but if you want to tidy everything up then let us know and we can perhaps dig a bit deeper and have a look at all the configs.
Jon
Our default gateway on our LAN is the firewall 192.168.1.14.
In terms of Cisco Switches: we have SW and SW3 and SW4 and Cisco24POE.  Total of 4 Cisco switches.  All Catalyst 3560's.  The first one we got was SW and here is its config (nothing is plugged into Fast eth0/1; also I removed most of the ports as they are all the same):
Using 6721 out of 524288 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW
enable secret 5 $1$Fq5g$vvR7eBEpmcarWk6tlMs1o.
no aaa new-model
ip subnet-zero
no file verify auto
 description CONNECTION TO SHORETEL FA0/1 ROUTER
 switchport access vlan 2
 duplex full
 speed 100
 description PHONE + PC
 description UPLINK-TO-24port-SW
interface Vlan1
 ip address dhcp
ip classless
ip http server
control-plane
line con 0
line vty 0 4
 no login
line vty 5 15
 no login
end
Here is the config from the 24-port switch:
Using 3801 out of 524288 bytes
version 12.2
no service pad
hostname Cisco24PoE
enable secret 5 $1$WH66$Zf7VOSZ5FN96T5AbH/5fM1
enable password <redacted>
no aaa new-model
ip subnet-zero
no file verify auto
 description PCs & Phones
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
ip classless
ip http server
control-plane
line con 0
line vty 0 4
 password <redacted>
 login
line vty 5 15
 password <redacted>
 login
end
Here is the config for SW4
version 12.2
no service pad
hostname SW4
boot-start-marker
boot-end-marker
username cisco privilege 15 password 7 060506324F41
no aaa new-model
vtp domain fub
ip subnet-zero
vlan 2
 name VOICE
interface FastEthernet0/46
 description UPLINK
 description UPLINK
 description UPLINK
interface Vlan1
 ip address dhcp
interface Vlan2
 ip address dhcp
ip classless
ip http server
control-plane
line con 0
 logging synchronous
 login local
line vty 0 4
 logging synchronous
 login local
line vty 5 15
 logging synchronous
 login local
end
If the default gateway for the data clients is the firewall then at least for data none of your switches appear to be routing that traffic ie. they are all simply acting as L2 switches even though they are L3 capable.
What is the default gateway for the VOIP clients ?
Do you want to manage all your switches via a static IP ?
Jon
Here is the info off my VOIP phone:
IP Gateway: 10.58.5.129
Subnet Mask: 255.255.255.128
VLAN ID: 2
This is provided by the Adtran router from its dhcp
I want to at least monitor the switches from Nagios (hence the desire to have them accessible via ping with a static IP.
I have never managed a Cisco switch via a static IP but that sounds attractive as well.
Here is my current config for the "SW3" which is the one I set to IP: 192.168.1.13
Current configuration : 9725 bytes
version 12.2
no service pad
hostname QUALBE-SW3
boot-start-marker
boot-end-marker
enable secret level 5 5 $1$PKEadfadfJbbcXqlHrvvN0
enable secret 5 $1$GSb.$1uuadfadfadfKlGSK1ywxEV//
enable password 7 04785A150C717D5B08sfdsfss2
no aaa new-model
ip subnet-zero
password encryption aes
spanning-tree etherchannel guard misconfig
 description UPLINK-TO-SW4
 description UPLINK
 description UPLINK
 description UPLINK
interface Vlan1
 ip address 192.168.1.13 255.255.255.0
interface Vlan2
 ip address dhcp
ip classless
ip route 0.0.0.0 0.0.0.0 10.58.5.129 254
ip http server
access-list 1 permit 192.168.1.17
snmp-server community qualbe-sw3-snmp RO 1
control-plane
banner motd ^C
If you are not explicitly authorized to login here, exit immediately.
^C
line con 0
 password 7 112A481614423A1905262921
 logging synchronous
 login local
line vty 0 4
 password 7 096F1F1A1A5526070A00062F
 logging synchronous
 login
line vty 5 15
 logging synchronous
 login local
end
sorry for the confusion...I was trying to obvuscate the IP info and that was a poor choice on my part.  I updated the above config info.  correcting the IP's.  Basically we have a flat data LAN on 192.168.1.0/24 and our current VOIP circuit starts with 10.58.5...   The Cisco switches are all Catalyst 3560 switches and our previous voice provider was managing them and now I'm trying to manage them.  All that to say, I believe the 172.... routes are all old and unused.  I'm not sure what is managing the routes.  How can I find out?
Now the switch is pingable...not sure what happened.  I can ping it at 192.168.1.13
In regards to the vlan1 on the 24-port Cisco....
interface Vlan1
should read:
interface Vlan1
I think this is an erroneous vlan1 definition on this 24-port Cisco as all the ports are setup to use voip and data...here's the full config:
version 12.2
no service pad
hostname Cisco24PoE
no aaa new-model
ip subnet-zero
no file verify auto
interface FastEthernet0/3
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface Vlan1
ip classless
ip http server
control-plane
line con 0
line vty 0 4
 password <redacted>
 login
line vty 5 15
 password <redacted>
 login
end
