How does traceroute work
shelley_wang
Level 2
Level 2
In what situations, *** are displayed which means a router in the path is not reachable?
Why after *** are displayed, traceroute does not stop, so user sees lines of ***.
Thx,
Jingyi
Lei Tian
HI Jingyi,
*** doesnt mean the router is unreachble, it just means the sender doesnt receive the ICMP ttl expired reply.
Here is the steps when IP A trace IP B
1,sender sends ICMP echo to destination B with ttl=1
2,next hop receive the ICMP packet, and reply  ICMP with ttl expired error message.
3,sender receive the ICMP reply or after timeout, sends ICMP echo to destination B with ttl-2
4,2 hops away router recive the ICMP packet, and reply ICMP ttl expired error message.
repeat the above steps until reach the destination, a ICMP destination unreachable error message is sent back to the sender.
On the sender, it will show as '* * *' if it doesn't receive a ICMP reply before timeout. That could because some security policy block the ICMP or just because link congestion.
Lei Tian
7 Replies 7
Jon Marshall
Thx,
Jingyi
Tracroute works by setting the TTL in the ip packet. Every time the packet goes through a L3 hop the TTL is decremented by 1. So the first packet traceroute sends out as a TTL of 1. The first router it gets to sets the TTL to 0 and sends an ICMP unreachable message back to the originating device with it's IP address. Then traceroute sends out another packet with the TTL set to 2 so it will get past the first router and to the second router. And this goes until the TTL is set to 30 usually.
Some routers can be configured not to send ICMP unreachables so you might see a *** instead but that doesn't mean the next router down the line won't send it's IP address so it traceroute does not stop, it simply adds 1 to the TTL and sends the packet out.
If all you see after the first *** is *** then it usually means there is no path to the destination.
Jon
woops, Jon, didn't see your reply while typing.
Lei
Your's was much better so i'm glad you didn't notice mine
Jon
Lei Tian
HI Jingyi,
Lei Tian
letian wrote:
HI Jingyi,
Lei Tian
Lei
I knew someone was going to correct me I should have checked before i responded, ie. it is ttl expired message not destination unreachable.
Thanks for clarifying.
Jon
Thanks so much for both of your detailed explanations.
I have 3 questions:
1.      Why the destination unreachable message is sent when destination is actually reached. It does not make logic sense.
2.      Who sends the destination unreachable message if the destination is a host. The local router, or the host?
3.      What if the destination is more than 30 hops away?
Jingyi
If of any help, please take a look at this blog post:
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
