how I can do health check for switch?
mahmoudyosry92
    I want to do health check for cisco switch 2950 and sg300 , how can i do that??
2 Accepted Solutions
Mark Elsen
   - FYI : https://community.cisco.com/t5/switching/health-check-of-a-switch/td-p/869862
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
To check the throughput of an interface use sh interface xx but not sure if there is a command that can give you the throughput for the whole switch. Usually, if your interfaces are not saturated, the whole system's throughput should be fine.
6 Replies 6
mahmoudyosry92
also how to know the traffic utilization/throughput , cpu and ram utilization ??
If you have NMS, you can see the info on the dashboard of the software, if not you would have to use commands like sh process cpu, sh log, sh interface, etc.. to get an idea.
hi,
thanks for the answer , is there any command to check the throughput of the whole switch or certain interface??
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
thanks for this link , it's so helpful.
is there any command to check the throughput of the whole switch or certain interface or it's impossible to know if I don't have NMS tool??
