How Improve Re-Convergence Times?
RobinCruz
I am measuring re-convergence times between LAN routers of between 1-5 seconds. Can the router settings be tweeked to improve that time?
Configuration is:
2 routers in cluster configuration on west side (R1, R2) to provide redundant links.
1 router on east side.(R3)
2 links connecting east to west (1 link prioritized so its primary).
2nd link is a failover link in case primary goes down.
Links configured for OSPF.
R1 \
| R3
R2 / (Lines represent the links)
When I pull Primary link to R3, it takes 1-5 seconds for link to re-establish the link on the secondary side.
Any thoughts appreciated.
Thank you!
royalblues
Level 10
Level 10
Are R1& R2 running HSRP and tracking the links status to R3?
Narayan
