how to add Vlan ACL in port mirror
Noovi
As i know we can do port mirroring in Cisco switches by following
monitor session 1 destination int g1/0/1
monitor session 1 source port g1/0/2 or source vlan 350
Can anyone tell me how i can use Vlan ACL in this scenario??
balaji.bandi
From my lab noted and tested one as below - change accordingly your stup.
When the source and destination are on the same switch that is refered as Local SPAN.
SPAN With VACL filter. Below is configuration example:
you can use standard and extended ACLs.
vlan 9
SPAN-VLAN
monitor session 1 source vlan 9
monitor session 1 destination interface g0/2
ip access-list extended NotIntestingTraffic
  permit ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
  permit ip 192.169.0.0 0.0.255.255 192.168.0.0 0.0.255.255
ip access-list InterestingTraffic
  permit ip 192.190.0.0 0.0.255.255 192.190.0.0 0.0.255.255
  permit ip 192.191.0.0 0.0.255.255 192.191.0.0 0.0.255.255
vlan access-map VACLSPAN 10
  match ip address NotIntestingTraffic
  action drop
vlan access-map VACLSPAN 20
  match ip address IntestingTraffic
  action forward
vlan filter  VACLSPAN vlan-list 9
BB
Hi ,
But i believe traffic will be dropped/discarded on switch but i dont want to.
i just want filtered traffic on SPAN.
I think we can do by below , as just found this.
Vlan Based:
monitor session 1 filter vlan 350 , 360 -365
IP Based:
monitor session 1 filter ip access-group 102
if you want to forward you can just do forward, not drop that should be ok. test and advise.
BB
