how to Attach Wifi Modem with VLANs
unleashed333
Greeting
I am unable to connect a Wifi Modem wiith 2960 Switch having VLAN 1,Attached is the network diagram,what configurations i have to modified it,
   (VLAN 10) 2960----------3750------------3750-----------2960 (VLAN1 )
I need to Connect A Wifi Modem on VLAN 1 ,Connectivity is working fine between VLAN 10 and VLAN 1.
What should be the next step to Connect Wifi Modem to VLAN 1 so that Users on VLAN 10 should connect to Internet..
Please reply and see the Attached Network Diagram
14 Replies 14
kcnajaf
Level 7
Level 7
HI Muhammad,
Need few informations here.
What is your 2960 switch port configuration looking like where you have connected the wifi modem?
Also what is your LAN side ip address for the wifi modem?
Najaf
Please rate when applicable or helpful !!!
Dear
2960 is in default condition (All devices are in VLAN1)
int vlan 1
ip address 192.168.1.227 255.255.255.0
Workstations
Ip details are 192.168.1.X ,Subnet Mask is 255.255.255.0,Default gateway is 192.168.1.227
Local IP of Modem is 192.168.2.1 /I can changed it as VLAN 1
Do you have 2960 configured as L3?
Najaf
No sir,It is Layer 2
If this is L2 you can not have this configured as the default gateway for the clients. You need to have some L3 device to act as the default gateway for your workstation.
Can you assign Local IP of Modem from the range 192.168.1.x and check if you are able to ping the modem ip from the workstation?
Najaf
I have connected a WIFI modem (ISP Provided) and configured IP of 192.168.1.228  and make a static route to this IP
ip route 0.0.0.0 0.0.0.0 192.168.1.228
All users on VLAN 1 is connected to Internet
But Users on other VLAN10(left side of picture) is unable to connect to internet
while I redistrubte static route to EIGRP..
please Reply
M.Navaid Javaid
Good to hear that you have internet on VLAN 1. May I know where you have put this static default route which points to 192.168.1.228. Is it on switch?
I assume the reason why you dont have internet from VLAN 10 is due to fact that your modem does not know about 192.168.15.x (vlan 10) network and hence it doesn't route to this network. I would assume that there is not much configuration you can do this modem to make this work. I'm not sure which wifi router you have there but if you could make this router aware of 192.168.15.x network you should be able to get internet working on from vlan 10.
Hope this helps.
Najaf
I made default Route on 3750 Switch but i have redistribute default route to EIGRP but did not get internet from VLAN 10
Hi Muhammad,
Redistributing the default route to EIGRP is not going to help you here much.Default route will help you to send all the traffic to your wifi modem on 3750. But the modem should have a route back to your other network (in your case vlan 10 -
192.168.15.x) for this to work. This is the issue which you are currently facing now. As far as your wifi modem is consered it know only the directly connected network 192.168.1.x and it doesn't have any clue of about 192.168.15.x network.
Another option you could try is enable NATing on 3750 which will translate all 192.168.15.x network to 192.168.1.x. At this point i dont know what is your configuration looking like on 3750 and hence not able to suggest much from the configuration presepctive.
I hope you are able to understand what i'm trying to say here.
Hope this helps.
Najaf
Dear Najaf
3750 did not have NAT feature,but I have one Routed port on eache 3750X switch and while other 12 ports are Mini GBIC support Only.what Option should You suggest me for this
Which is this 3750x? I dont see any 3750x on your diagram. I wouldn't be able suggest anything with out understanding the exsisting configurations on your devices.
Najaf
Dear
In original this is 3750X but i used 3560 in Packet tracer
3750X ON LEFT
enable password cisco
ip routing
interface FastEthernet0/1
no switchport
ip address 10.0.0.2 255.0.0.0
duplex auto
speed auto
interface FastEthernet0/2
switchport mode trunk
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.1.99 255.255.255.0
router eigrp 10
network 192.168.1.0
network 10.0.0.0
auto-summary
ip classless
ip dhcp excluded-address 192.168.10.0 192.168.10.50
ip dhcp pool VLAN10POOL
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.168.1.100
ip routing
no switchport
ip address 10.0.0.1 255.0.0.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
router eigrp 10
network 10.0.0.0
network 192.168.20.0
auto-summary
ip classless
3750X on RIGHT
ip routing
no switchport
duplex auto
speed auto
interface Vlan1
router eigrp 10
network 192.168.1.0
network 10.0.0.0
auto-summary
ip classless
Thanks a lot for sharing confiration.
Last time you have mentioned that you have put a default route..Where is that you have put this default route?
How is your NAT and interface configuration looking like on Wifi router?
Also do you have an option of wifi router to put static route? If this is possible then you dont need any NAT.
Najaf
ip route 0.0.0.0 0.0.0.0 192.168.2.1
Wrong configuration pasted ,
The modem that ISP provided me did not have any option of NAT and Static Route..
