How to Check Backplane Utilization on 2960G
dbuckley77
Is there a command to check the current utilization of the backplane on a WS-C2960G-48TC-L switch?
Reza Sharifi
Not sure if there is a backplane command, but you can try:
sh platform resource
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_53_se/command/reference/2960ComRef/showplat.html
Joseph W. Doherty
I'm unaware of a specific command for that purpose, but if there isn't, the aggregate sum of all your ports egress rate should "be in the ballpark".
