Length of CAB-C15-CBN?
aukhadiev
can anyone suggest the cable length of CAB-C15-CBN?
InayathUlla Sharieff
It should be 2.3 ft.(69cm)
Power cable - IEC 320 EN 60320 C14 - IEC 320 EN 60320 C15 - 2.3 ft - for MDS 9020, 9120, 9140, 9216, 9216A, 9216i
Inayath
        *Plz rate if this info is helpfull.
10 Replies 10
Inayath
Thanks for the info...
Why a low rating of 3 to an answer 100% correct and made with the will to help !?! That should never be done!
I've re-rated the posting to partially compensate.
Thanks Paolo.
Hi, Paolo...Please look PM...
The low rating may be because two values appear, depending where you look - 69cm/2.3ft or 1.22m/4ft.  It is possible they have supplied 69cm ones in the past, but the ones supplied over the past few years are 1.22m/4ft
CAB-C15-CBN is 1.22m/4ft (just confirmed with the aid of a tape measure)
(CAB-C15-CBN-CK, CAB-C15-CBN-JP and CABC15-CBN-EURA appear to be 3m/9.1ft)
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/hw/9396T/cisco_mds9396T_hardware_install_guide/cable_port_specs.pdf
ciscoazlancco
Is there an alternative part code for a longer cable ( same connectors ) ?
Try third part ENET -     CAB-C15-CBN-6F-ENC
