How to check interface usage under catos?
amin.amor
I would like to know how to check the current interface usage on 6509 running CATOS? The interfaces are configured under a VLAN or as trunk. Could you please let me know which command is appropriate in order to check the current interface usage?
show mac x/x just show you the total packet received from the last clear. interface
Your network partner in Luxembourg
http://www.itnet.lu
5 Replies 5
s-sheffield
under CATOS I usually use,
show port counters
show port mac
hope this helps
Stu
Hi Amin,
you can also type "show port " to know other detailz.
ankbhasi
Thanks, this is the best answer. sh top uti
http://www.itnet.lu
m.sir
Level 7
Level 7
try command
show port mac utilization x/x
you get 5 minutes input/output port rates
M.
hope that helps rate if it does
