how to check nexus 7000 fex fan and power supply issue
baselzind
Level 6
Level 6
on solarwinds a fex on the nexus 7000 is showing a fan and power supply issue , how can i check it on nexus 7000 and how can i know which external one is suffering from the issue? also in the attached picture one psu is showing "offdenied" , what does that means?
Mark Malone
Hi login to the nexus and run this command , alos the faulty PS will have a red LED light on it
do you have dual power supply's in that FEX ?
# sh environment fan
Fan:
Fan             Model                Hw         Status
Chassis-1       N5596UP-FAN-B        --         ok
Chassis-2       N5596UP-FAN-B        --         ok
Chassis-3       N5596UP-FAN-B        --         ok
Chassis-4       N5596UP-FAN-B        --         ok
PS-1            N55-PAC-1100W-B      --         ok
PS-2            N55-PAC-1100W-B      --         ok
Or 7k
Fan:
Fan             Model                Hw         Status
Fan1(sys_fan1)  N7K-C7009-FAN        1.0        Ok
Fan_in_PS1      --                   --         Ok
Fan_in_PS2      --                   --         Ok
Fan Zone Speed: Zone 1: 0x7f Zone 2: 0x30 Zone 3: 0x30 Zone 4: 0x0
or show environment .. will show everything
For particular FEX use
# sh environment fex 101
Temperature Fex 101:
Module   Sensor     MajorThresh   MinorThres   CurTemp     Status
                    (Celsius)     (Celsius)    (Celsius)
1        Outlet-1   80            80           35          ok
1        Outlet-2   80            80           36          ok
1        Inlet-1    80            80           35          ok
1        Die-1      125           100          43          ok
1        Control-1  70            60           35          ok
Fan Fex: 101:
Fan             Model                Hw         Status
Chassis         N2K-C2248-FAN        --         ok
PS-1            N2200-PAC-400W       --         ok
PS-2            N2200-PAC-400W       --         ok
Power Supply Fex 101:
Voltage: 12 Volts
PS  Model                Power       Power     Status
                         (Watts)     (Amp)
1   N2200-PAC-400W        396.00     33.00     ok
2   N2200-PAC-400W        396.00     33.00     ok
Mark Malone
Fan:
Fan             Model                Hw         Status
Or 7k
Fan:
Fan             Model                Hw         Status
Fan_in_PS1      --                   --         Ok
Fan_in_PS2      --                   --         Ok
Fan Fex: 101:
Fan             Model                Hw         Status
Voltage: 12 Volts
                         (Watts)     (Amp)
