How to check on Chassis fan-tray status - 6509
lukeprimm
I believe my Chassis fan tray might be going bad in my 6509 and I am wondering on how to check the status?  Thanks
johnlloyd_13
Level 9
Level 9
Use the show environment command.
johnlloyd_13
Level 9
Level 9
lukeprimm
Thanks, strange, My NMS was showing Fan-tray 1 as "failed" but here it appears to be good.  I assume
"fan-tray 1 fan-fail: OK" means its alright.
6509#show environment
environmental alarms:
  no alarms
backplane:
  operating clock count: 2
  operating VTT count: 3
fan-tray 1:
  fan-tray 1 type: WS-C6K-9SLOT-FAN2
  fan-tray 1 version: 2
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 27C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 25C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 30C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC high
  power-supply 1 power-output-mode: high
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC high
  power-supply 2 power-output-mode: high
  power-supply 2 power-output-fail: OK
module 1:
  module 1 power-output-fail: OK
  module 1 outlet temperature: 35C
  module 1 inlet temperature: 23C
module 2:
  module 2 power-output-fail: OK
  module 2 outlet temperature: 47C
  module 2 inlet temperature: 24C
module 3:
  module 3 power-output-fail: OK
  module 3 outlet temperature: 45C
  module 3 inlet temperature: 25C
module 4:
  module 4 power-output-fail: OK
  module 4 outlet temperature: 25C
  module 4 inlet temperature: 24C
  module 4 device-1 temperature: 22C
  module 4 device-2 temperature: 28C
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 29C
  module 5 inlet temperature: 23C
  module 5 device-1 temperature: 34C
  module 5 device-2 temperature: 34C
  module 5 asic-1 (SSO-1) temp: 23C
  module 5 asic-2 (SSO-2) temp: 23C
  module 5 asic-3 (SSO-3) temp: 23C
  module 5 asic-4 (SSO-4) temp: 23C
  module 5 asic-5 (SSA-1) temp: 23C
  module 5 asic-6 (HYPERION-1) temp: 23C
  module 5 RP outlet temperature: 27C
  module 5 RP inlet temperature: 27C
  module 5 EARL outlet temperature: 37C
  module 5 EARL inlet temperature: 23C
module 6:
  module 6 power-output-fail: OK
  module 6 outlet temperature: 29C
  module 6 inlet temperature: 22C
  module 6 device-1 temperature: 34C
  module 6 device-2 temperature: 34C
  module 6 asic-1 (SSO-1) temp: 23C
  module 6 asic-2 (SSO-2) temp: 23C
  module 6 asic-3 (SSO-3) temp: 22C
  module 6 asic-4 (SSO-4) temp: 22C
  module 6 asic-5 (SSA-1) temp: 23C
  module 6 asic-6 (HYPERION-1) temp: 23C
  module 6 RP outlet temperature: 28C
  module 6 RP inlet temperature: 28C
  module 6 EARL outlet temperature: 36C
  module 6 EARL inlet temperature: 23C
module 7:
  module 7 power-output-fail: OK
  module 7 outlet temperature: 44C
  module 7 inlet temperature: 21C
module 8:
  module 8 power-output-fail: OK
  module 8 outlet temperature: 44C
  module 8 inlet temperature: 23C
chassis connector rating: 1260.00 Watts (30.00 Amps @ 42V)
module 1
  module 1 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 1 power consumption: 152.04 Watts ( 3.62 Amps @ 42V)
module 2
  module 2 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 2 power consumption: 277.62 Watts ( 6.61 Amps @ 42V)
module 3
  module 3 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 3 power consumption: 325.50 Watts ( 7.75 Amps @ 42V)
module 4
  module 4 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 4 power consumption: 125.16 Watts ( 2.98 Amps @ 42V)
module 5
  module 5 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 5 power consumption: 315.00 Watts ( 7.50 Amps @ 42V)
module 6
  module 6 connector rating: 1260.00 Watts (30.00 Amps @ 42V)
  module 6 power consumption: 315.00 Watts ( 7.50 Amps @ 42V)
module 7
  module 7 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 7 power consumption: 325.50 Watts ( 7.75 Amps @ 42V)
module 8
  module 8 connector rating: 2016.00 Watts (48.00 Amps @ 42V)
  module 8 power consumption: 325.50 Watts ( 7.75 Amps @ 42V)
chassis per slot cooling capacity: 70 cfm
ambient temperature: < 55C
  module 1 cooling requirement: 30 cfm
  module 2 cooling requirement: 70 cfm
  module 3 cooling requirement: 70 cfm
  module 4 cooling requirement: 70 cfm
  module 5 cooling requirement: 35 cfm
  module 6 cooling requirement: 35 cfm
  module 7 cooling requirement: 70 cfm
Did you find out why this was, I see the same thing CLi shows it as fine, but an SNMP walk...
ciscoEnvMonFanStatusDescr.101 chassis-1 Chassis Fan Tray 1
ciscoEnvMonFanStatusDescr.102 chassis-1 Power Supply 1 Fan
ciscoEnvMonFanStatusDescr.103 chassis-1 Power Supply 2 Fan
ciscoEnvMonFanStatusDescr.201 chassis-2 Chassis Fan Tray 1
ciscoEnvMonFanStatusDescr.202 chassis-2 Power Supply 1 Fan
ciscoEnvMonFanStatusDescr.203 chassis-2 Power Supply 2 Fan
ciscoEnvMonFanState.101 normal(1)
ciscoEnvMonFanState.102 normal(1)
ciscoEnvMonFanState.103 normal(1)
ciscoEnvMonFanState.201 critical(3)
ciscoEnvMonFanState.202 normal(1)
ciscoEnvMonFanState.203 normal(1)
Clearly shows it as critical??
This is the state of the chassis fan. It cannot be seen in the "sh env".
