How to check the switch is in ROMmon or not
Mr.Kumar
Hello All,
I have switch C2960 which was broke and not able to turn on after a power recycle, so i was asked to check whether the switch is in ROMMON or not, could someone help me how to check it. Thanks in advance
msharayri
hi ,
just access the device through a console .
7 Replies 7
msharayri
hi ,
That's it? and what to check after accessing it, i'm new so don't mind if i'm asking silly questions. Thanks in advance
Leo Laohoo
You look at the prompt in the console screen. If the prompt is "rommon>" then it's self-explanatory.
If you have no access to console then look at the display. In ROMmon, the port lights should be off and the "SYST" LED should be blinking green.
Hi Leo,
Thanks for your response. I consoled into the switch and it's not in ROMmon, it is keep on booting. what does it mean?
Pranay
If you've consoled into the appliance, post the entire boot up process. We would like to see what is going on.
Hi Leo,
Attached is the boot up process which is on going on switch. Thanks
Try a different IOS.
